Installing Holley fuel pump
Old Mar 22, 2002 | 09:14 PM
crafoo's Avatar
Well, I've got the FPR and gauge installed from the Holley Blue kit no prob. That was easy.
I pulled down the stock pump and the nice little metal plate it mounts to. My problem is the Holley pump is a good deal larger. Also, the holley docs say to install the pump in an "upright position", with the electric motor above the rotar/vane assembly. The docs also say to mount the pump so that the tank can gravity feed the pump.
How important is it to mount the pump in this way? I was planning on laying it on it's side and reusing the stock rock-guard metal plate. If the stock plate doesn't fit I'm considering getting some thin steel metal and forming it to fit.
Old Mar 23, 2002 | 12:20 AM
REVHED's Avatar
Hunting Skylines
I'd say the mounting instructions are there for a reason. See if you can mount it on the frame rail where it starts to curve up before the diff. That's where I put my Carter.
Old Mar 23, 2002 | 07:48 AM
crafoo's Avatar
Yes, I considered that location. I was worried about clearance issues and protecting it from road debris. It's a very big pump: much "taller" than a carter pump.
Old Mar 23, 2002 | 08:56 AM
mar3's Avatar
Administrator
That is, perhaps, the only redeeming value of the budget Carter...
Old Mar 23, 2002 | 12:11 PM
hanman's Avatar
My understanding is that you will jeopardize the life of the pump by mounting any other way than vertical. I have the Carter mounted.........that's right, right before the axle on the frame rail.
hanman
Old Mar 24, 2002 | 06:11 AM
crafoo's Avatar
BAH! This was supposed to be a 2hr. project! Funny how it never works out that way.
Thanks all for the good info. I'll shoe horn this sucker up on the frame rail somehow. Hmmmm, maybe I should fire up the blue wrench
Queppa
Nov 18, 2024 03:47 AM
