Haltech E6K map to E8 Map. Batch VS SEQ
Old Apr 13, 2007 | 04:27 PM
IAN's Avatar
IAN
Rotary Reborn!
I had my E6K map converted to the E8. Obviously the E6K was set to Batch. Currently my E8 is set to Sequential/Staged.
Unknowingly I was beginning to question my fuel configuration and since i think I may have issues with my Wideband I was not sure what was happening. It appeared to be running lean. Car idled fine and looked to be around 12.5. (I don't think that was in coolant correction mode either.)
I called haltech and my understanding is that if you convert the E6K batch mode fuel map into E8 running Sequential you are in theory running half the fuel.
Is this correct. If so how come I could get the car to start and drive what appeared to be normally down the street? (That one squeeze of the throttle hitting 9psi probable was not a good idea!)
Any ideas. I know I am posted alot of questions lately
Ian
Old Apr 13, 2007 | 06:01 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Ian
Yes, that is exactly right. The simple solution is putting the fuel mode exactly as it was in the K, or, you just retune. Its a little time consuming but thats what you have to do.
Old Apr 13, 2007 | 08:53 PM
nik's Avatar
nik
So for anyone else doing this kind of conversion of maps from batch to sequential, would it be reasonable to just double all the fuel map and retune from there?
Haltech also mentioned the injector dead time, and tuning that into the battery correction map. Most people don't really do this on the early haltechs, and the dead times just get absorbed into the fuel map. I guess this will just make the doubled map richer, not necessarily a bad thing.
I am really surprised his car would have run at all with 1/2 the fuel delivery required...
Old Apr 13, 2007 | 09:05 PM
slo's Avatar
slo
registered user
That doesn't sound right, but I don't kow anything about the K.
I was under the impression that batch mode would toggle between the 2 injectors, which wile not identicle to sequential in that its not timed thats the same amount of fuel. I think what happening is its getting to the staging bar where the k would be firing both secondairy injectors at the same time and firing them sequentially. I think thats where youve got half the fuel you need, which would explain why it drives normally untill it hits the staging bar.
Of course I could be way off, I am not an expert... Claudio is
Old Apr 13, 2007 | 09:07 PM
EFI Tech Wannabe
Yes, me too, thats why i dont think its a linear doubling of the map values, since he stated his car idled. But then again it could've also meant that he was rich to begin with. But at any rate, it takes a whole retune to get it right when changing fuel delivery mode.
Thats why i suggested to leave the fuel settings as they were in the K to get it running. Then if you want to retune it completely later on as sequential you have your work cut out for you. Either that or find a reputable tuner.
Old Apr 13, 2007 | 09:20 PM
IAN's Avatar
IAN
Rotary Reborn!
Well I asked haltech if all it would take is for me to double the injector pulse and they said sure. But adding another 100% seems to me your increasing the duty cycle of the injectors to much? They did not mention anything about there being a difference in the primary side of the map response to the secondary injection running in seq. Just that it was quite possible I could run my car that lean. I'm surprised it started.
They did mention that I would not notice a difference between batch mode and sequential. Sequential has better fuel control. Must be more noticable in piston motors.
Nik was the person who converted my E6K map to E8.
I was confused about my car idling and driving. Holding the car in idle at 3500 rpm it did go lean.
I am still lost in injection lost time and not even sure how you program that aspect of it. (I'm not even sure on that end of iseq njection ° stuff. Maybe that was what they were making reference too.)
So needless to say tomorrow I'm going back to batch. And spend another day to see why I have such a difference in my wideband indicators.
Old Apr 13, 2007 | 09:36 PM
nik's Avatar
nik
Yep, all I did was convert his ign and fuel maps over from e6k. Just used linear interpolation where the points changed.
Ian, I guess the plan is to go back to batch for the MCO school? Once that is over you should try to get the seq inj mode working, and then we can do a before/after comparison of the fuel maps to figure this thing out.
Old Apr 14, 2007 | 01:18 AM
RETed's Avatar
Actually, it depends on how the E6K is set-up?
If it's " / 2", then it's actually backwards - the E8 would be running TOO MUCH fuel, approximately twice too much.
-Ted
Old Apr 14, 2007 | 07:16 AM
IAN's Avatar
IAN
Rotary Reborn!
-Ted
I had it set to /2. But I believe Haltech was aware about that and he did not change his answer. At the end of my conversation I made sure I said so switch the E8 to Batch divided by 2? He said yes.
Old Apr 14, 2007 | 12:31 PM
RETed's Avatar
Hmmm, didn't think you could do that.
Everytime I looked at the E8, it was always set to sequential with no way to change the "divide by" setting.
-Ted
Old Apr 14, 2007 | 02:45 PM
IAN's Avatar
IAN
Rotary Reborn!
Well I drove around with it set to batch mode /2. I can't see a difference from Batch mode and sequential but my wideband seems to have a error from 1A/F to 2A/F between logworks and the display. I can't get consistant readings and I can't stare at the logworks program during accel fast enough.
Just gonna have to wait for nik and his wideband.
ls1swap
Jun 3, 2024 03:25 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
