What do I need to put a T2 diff on???
Old Mar 22, 2002 | 05:42 PM
VtekEater's Avatar
Hey guys just want to know what all the parts that are needed to to this swap??
My N/A one has had it So time for an upgrade
Old Mar 22, 2002 | 06:34 PM
jimmyv13's Avatar
Round&Round not Up&Down
It's not just a bolt in item.
You'll need an entire TII driveline:
half-shafts, diffy, driveshaft, tranny (maybe something different with the FW's or counterweights, I'm not sure. Consult Mazdatrix for verification, or someone on here will tell you).
OR:
If you want to keep your NA tranny, you can cut a TII driveshaft in half and an NA driveshaft in half and weld the front of the NA shaft to the back end of the TII shaft. Then your TII differential will work, but you'll still need TII half-shafts.
Old Mar 22, 2002 | 06:58 PM
VtekEater's Avatar
Cool thanx for the info man, I did sorta figure about the half shafts but wasnt sure, also I heard somewhere that an auto drive shaft has the same flange as the T2 rear end flange, is this true???
Old Mar 22, 2002 | 07:00 PM
Felix Wankel's Avatar
Super Newbie
The auto one is for the TII trans to NA diff.
Old Mar 22, 2002 | 07:05 PM
VtekEater's Avatar
Oh whoops
Thanx for pointing that out man
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
rx7shirley
Sep 2, 2015 02:11 PM
kkev.7788
Sep 2, 2015 01:32 PM
