3rd Gen BOPs IMO
Old Mar 22, 2002 | 08:34 AM
amp's Avatar
amp
old yella
3rd Gen BOPs IMO
..just got my Block off plates yesterday..
a bit disappointed in that it didnt include a BOP for the flange from the hard pipe (in front of the UIM) that leads to the ACV...it also does not include a BOP for the flange after removal of the air pipe that leads to the cat...i figured if this set was for emissions removal, it should include these as well....oh well..should have just had a shop do the complete set....or are these even required to be blocked off ?....
oh...
and didnt get any gasket material...and i believe it was posted that they were suppose to include these as well...
Old Mar 22, 2002 | 08:42 AM
phatmonky's Avatar
William
Could you explain that in english for a piston guru such as myself
I am interested in learning, but too man acronyms and things I don't know about rotaries
Old Mar 22, 2002 | 09:08 AM
spooledUP7's Avatar
There and back again
BOP = Block Off Plate
ACV = Air Control Valve
UIM = Upper Intake Manifold
... = too many hours in chat rooms...
Old Mar 22, 2002 | 09:15 AM
phatmonky's Avatar
William
Thanks
now on to searching so I understand what the hell is going on
Old Mar 22, 2002 | 09:17 AM
ttpowerd's Avatar
HARRRRRRRRR
true true...hehehe....
I don't know too much about block off plates and would like to learn as well, anyone got any info we can browse through?
Thanks
Old Mar 22, 2002 | 01:16 PM
Import Convert's Avatar
I plan on making my own. Seriously, it cannot be that hard, and I'll be rebuilding my engine sometime so everything will be apart. Just get a piece of sheet metal (of generous thickness), and cut shapes to fit.
Old Mar 23, 2002 | 12:37 AM
amp's Avatar
amp
old yella
Originally posted by Import Convert
I plan on making my own. ..........
..is what i should have done myself and just reuse the existing gaskets if its even required..
Old Mar 24, 2002 | 05:27 AM
amp's Avatar
amp
old yella
did the missing BOPs myself using aluminum..much lighter than the ones for sale as they use SS and reused the metal gaskets, replaced the others i couldnt reuse with gasket material..
demetlaw
Oct 2, 2015 06:22 PM
