100LL and Water Injection
Old Apr 7, 2007 | 07:27 PM
finnicky7's Avatar
26.55 psi T04Z Monster
Just finishing off my new T04Z setup. I am contimplating where I want to go with this setup. I have been running a coolingmist H2O inj. for 2 years with no problems, but that was at 20psi and 94 octane. I now want to see what this turbo can do, and from my understanding 25+psi is where is at. C16 is an option but at $10gal I'd preffer some other sources for fuel.
If anyone has any input it would be greatly appreciated?
Old Apr 7, 2007 | 08:21 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
love your turbo. so will you. nice choice. everyone has there opinion re AI. here's mine.
methanol. it is magic.
i am making over 500 rw w 1100 degree F egts and no knock w two M10 nozzles. it has been easy to tune. whereas before meth i was at 90% duty cycle w 850/1600s i am now at 70% duty on pump w the meth.
there are a number of decent threads in this section, check them out.
if you have questions ask away........
good luck,
howard coleman
Old Apr 7, 2007 | 08:32 PM
finnicky7's Avatar
I'm looking for some added safety. I am running a 1 bar spring in my WG so I would like to be tunned for 1 bar on 94 octane, and then used 100LL with h20 for anything above that.
FYI 100LL is $3.25-4.00 gal
Old Apr 7, 2007 | 08:47 PM
you are looking for "safety" and at the same time turning up the boost from 20 to 25.
i suggest you are looking for POWER. more power than 20 psi.
but you don't want to hurt your motor.
i recommend you seriously consider 100% methanol. $1.99 a gallon in wisconsin.
i will be happy to show you my logs. 525 rwhp at 59% throttle, 18 psi boost, 1100 degree F egt pre turbo, and 30 knock on a Power FC. on 93 pump w 1200 CC minute methanol.
i don't know how much lead 100LL has but i do know lead fries O2 sensors.
there are lots of ways to get to where you want to be. maybe your plan w 100LL and water will work fine. should you be of a mind to consider alternatives i offer methanol. it works for me.
howard
Old Apr 8, 2007 | 05:48 PM
radkins's Avatar
DO NOT USE 100LL!!!!
I ran that stuff almost 2 years and realized that you actually loose power from it and it clogs the **** out of O2 sensors. Trust me on this. Stick with a real race gas.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
