Canadian Forum Canadian users, post event and club info here.
Help with Wiring New Headlights.
Old Mar 31, 2007 | 12:25 AM
misterstyx69's Avatar
Retired Moderator, RIP
I am Thinking about wiring in some Aftermarket Xenon Bulbs,with Hella CasingsOn a Second Gen ..the Power is going to be More than What you usually Deal with ..80-100 watts..Does anyone have any ideas as to How to wire these up Onto a Separate wiring Harness(due to power,It may Melt the Stock harness!) but Run it with relays to Use the Stock headlight switch?..any info?.Leads?.Links?,Pics?..Thoroughly appreciated gentlemen..Thanks..Styx.
Old Apr 3, 2007 | 03:47 AM
oh Come on guys!..If it had a Turbo in it..you would be all over this givin me info til it came out My ears!!!...OK..They are TURBO bulbs with Turbo Hella Casings!..anyone?..(even Ferris would be responding!..(hahahaha)..But I will settle for a Wiring Guru!..Thank you!..STYX!~
Old Apr 3, 2007 | 07:08 AM
darkfrost's Avatar
Pretty straightforward, Ground the negative post of each bulb, For headlights / highbeams, run a relay (1 for highbeams, 1 for regular) activated by the current power wire for your headlights, and then direct battery connection to the new ones.
Make sure to put a fuse in-line as well.
This way your switches still run your lights, and you get as much power as you want to them.
This foglight wiring diagram should help:
http://www.classictruckshop.com/club...ch/foglite.jpg
Forget the whole indicator thing, and to pin 85 is your current power wire that goes to the headlights.
Hope this helps
Old Apr 3, 2007 | 11:52 AM
sirx7's Avatar
here i will help you out
if you are using true Xenon and not xenon style or look like bulbs
they will have ballast and the ballast will typically have a 2 wire plug in and big fat plug out which will plug into a D2S bulb typically
in either case you make seperate harness so u can still revert to stock by unplugging everything follow my pic here PM for more answers
just replace the H9 plug with your xenon plug
Old Apr 5, 2007 | 04:45 PM
Thanks guys!..pretty well Spot on what I was lookin for..NO,the bulbs don't have a Ballast.the Set is out of a JEEP,that had these 80/90 watt HID's installed.The guy did alot of Rural driving,and DEER were Rampant.The bulbs Did Fry his harness a bit though,so I am not taking chances putting them In Until I know all will be OK to Install in the FC..I Would be Totally Pissed to have to scout through the headlight wiring,especially Under the dash IF the Install Was done improperly,..so I am contemplating on Doing it ONCE..The RIGHT way!..cheers guys.STYX!~
Old Apr 5, 2007 | 05:34 PM
soulja77's Avatar
hey i have an HID kit for the fc, but one of the converter is not working for some reason. Its basically plug and play. The bulbs work fine. I paid 200 for it, would like to get that back.
lemme know.
Old Apr 5, 2007 | 09:11 PM
no thanks Mike,thanks for the offer, but,I can get by with What I got..Hell I got Five cars Worth of Parts here..
Old Apr 5, 2007 | 10:01 PM
soulja77's Avatar
if anyone knows of an electrician who can repair a converter, let me know.
HID do make the FC look more modern!
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
