Megasquirt trailing not working still
Old Mar 25, 2007 | 01:31 AM
turbosa22c's Avatar
ok heres my msq. if you an find something let me know.
File Type: zip
Old Mar 26, 2007 | 01:07 PM
T2GTUS's Avatar
iirc, I don't think the trailing table likes negative numbers ... and I believe any number 20+ also disables trailing. Did you try setting the trailing timing fixed and time it with a light?
Old Mar 26, 2007 | 02:34 PM
muythaibxr's Avatar
MegaSquirt Mod
I'm not sure what negative numbers will do, but numbers greater than 20 will definitely turn off trailing.
Ken
Old Mar 27, 2007 | 11:50 PM
turbosa22c's Avatar
I figured it out. i found a bad ground on the 300ohm resistor on the lm circuit. im not really sure how this affects the trailing though. i found it by accident when i was handling the circuit. trailing now fires and the stock tach works. im not sure but i think there is some error with the stock tach. it says im idling at 500 rpm or less. i couldn't confirm the idle on megatune because i left my laptop at work.
Old Mar 28, 2007 | 11:30 AM
muythaibxr's Avatar
MegaSquirt Mod
Sometimes the stock tach can be off a bit.
I've seen them off by up to 300 rpms.
Ken
freq
Microtech
Aug 23, 2015 11:02 AM
freq
Aug 21, 2015 03:30 PM
Wolf_
Aug 11, 2015 04:23 PM
