is 12psi of boost safe with...
Old Mar 20, 2002 | 02:08 AM
legendr35's Avatar
...Gforce ECU, midpipe, 3" Muffler, Downpipe and Y-pipe?
ThankS
Old Mar 20, 2002 | 02:56 AM
rynberg's Avatar
Just to be safe, you should probably upgrade your fuel pump. Even getting the somewhat pricey Nippon Denso (rx7.com, SR motorsports, other places) fuel pump is only about $250. And it's a direct drop-in replacement. Just consider it extra insurance.
Old Mar 20, 2002 | 06:00 AM
ttpowerd's Avatar
HARRRRRRRRR
little more fuel would never hurt
Old Mar 20, 2002 | 11:45 AM
artguy's Avatar
WTB** Very Low Miles 94-95
its safe as long as you have dough in the bank.
Old Mar 20, 2002 | 11:56 AM
Toadman's Avatar
Nomad Mod
Heh.. Jason.
Got those ball-bearing turbos installed and breaking her in yet?
Old Mar 20, 2002 | 06:41 PM
justin's Avatar
With your mods no problem at all.Remember your only above the factory specs by a 1lb or two of boost
Always run the highest octane gas you can find.Plenty of guys run 13lbs on the street all the time
without problems.14lbs.seems to be the magic # not because of the apex seals or eng.but
because of the fuel system and injector duty cycle which becomes maxed out. With proper fuel and
tuning stock apex seals can be good for 16-17 lbs boost
Bauer778
Nov 4, 2015 04:42 PM
Snook
Oct 4, 2015 08:47 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
