help bleeding clutch
Old Mar 19, 2007 | 02:00 AM
808rx7's Avatar
im thinking about bleeding my clutch tomarrow...could some one tell me or give me a link of a how to? thanks.
Old Mar 20, 2007 | 04:27 PM
topthriller7's Avatar
Make sure you have a lot of fluid on you to do it. Also have a bleeder kit that has a tube with the collecting cup at the end.
Its kind of a 2 person job, but you can do it yourself. Follow the clutch line to the bottom of the tranny. It will take you to the slave cylinder; you should be able to see a small nipple right next to the hose. Hook up your bleeder kit to the nipple and take a small wrench (8mm I think) and turn it loose. Then take the cap off the clutch reservoir and start pumping the clutch pedal. Enjoy.
Old Mar 21, 2007 | 12:16 AM
tooslow7's Avatar
go get a haynes manual
Old Mar 21, 2007 | 12:20 AM
808rx7's Avatar
i already looked at the haynes maual on the FAQ sticky but wanted more info because it wasnt quite clear.
Old Mar 21, 2007 | 12:29 AM
TehMonkay's Avatar
Back in the game
you should be able to do the clutch by yourself, when you unscrew the bleeder the assist spring will make the spedal stay on the floor and you can go tighten the screw.
Old Mar 21, 2007 | 12:31 AM
808rx7's Avatar
^ and just keep doing that until it all bleeds out?
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
