injector calculators; have I maxed 720's on stock turbo?
Old Mar 18, 2007 | 12:43 PM
arghx's Avatar
rotorhead
I've got an 88 T2 with an aggressive street port (Turrentine said it was practically the most aggressive you can do without going bridge etc) and s5 turbo. On the stock ECU with a fuel cut defender the car runs lean once it hits about 12psi (i have been winding it out to about to about 14, I know this is a lot but I've got FMIC). AFR's have climbed into the 13's--I am currently running 100 octane unleaded as I've been trying to sort this problem out.
I have the SAFC richened up 20% and it doesn't help much once the boost climbs (it makes it run mad rich in 1st though b/c the boost doesn't climb very high).
The car has a rewired Warlbro 255 with stock FPR. It's only lean when the boost is high--so when it will richen up again by redline once the stock turbo can't hold the boost.
I've been looking at this fuel injector calculator thing http://rx7.com/cgi-local/2ndgencalc.cgi . It says that the stock ECU runs the injectors 58-63% duty cycle. I really don't believe that number though--I thought the rule of thumb was closer to 80%. Like it says that the stock 550/550 can only do 200 at the flywheel at 63% duty cycle, but I know plenty of people break 200 at the wheels on stock injectors just fine.
So do you guys think I just have injectors that are too small? The car dynoed 250rwhp a while back running no boost controller but a lot of boost creep (about 12psi maybe). I'm going to upgrade the injectors when I install my FPR anyway, and obviously the solution for now is to keep the boost down.
Old Mar 18, 2007 | 03:07 PM
icecreaman's Avatar
hence tuning fuel to boost is better than rpm, i wonder if your boosting at different parameters than the AFC will handle. Most likely tho if you hit around 250whp, its time to up your injectors
Old Mar 19, 2007 | 12:18 AM
eriksseven's Avatar
Make Money.
I think you should pull your turbo and port the WG more agressively to prevent the boost creep you're getting in the higher gears... If you're running a 3" TID and full 3" exhaust, you should be able to keep the boost at or below 10psi with a good port on your s4 WG... So yeah, do this and then you can hopefully tune your SAFC better for all the gears (instead of just 4th gear where you get the most boost-creep).
It's a good thing you've got 100 octane and a FMIC. 13 AFR's wouldn't last long for any other setup.
Old Mar 19, 2007 | 01:04 AM
arghx's Avatar
rotorhead
well I'm just waiting to get some more money and i'm going to rip this bitch apart to give it a standalone, injectors, and FPR.
Old Mar 19, 2007 | 01:24 AM
eriksseven's Avatar
Make Money.
Either way, you should probably redo the WG port to get more consistent boost IMO. It will make tuning that SAFC a LOT easier.
Old Mar 19, 2007 | 03:51 AM
NZConvertible's Avatar
I'm a boost creep...
Jeez I wish that'd remove that BS claim for that page. Firstly, injectors are not run at a certain duty cycle as that statement implies, the duty cycle varies massively depending on load and rpm. DC at idle for example is only 3-4%. Secondly, the injectors peak at ~60% when the engine's stock, but this is not a limit. I have a dash-mounted digital injector duty cycle meter and I can assure you it can get higher than 63%.
Old Mar 19, 2007 | 07:42 AM
arghx's Avatar
rotorhead
Well, it is a marketing tool to convince you to buy their injectors etc.
Old Mar 19, 2007 | 08:47 AM
SureShot's Avatar
Seduced by the DARK SIDE
Check your AFM flow % on the S-AFC.
At WOT the AFM could be 100% as low as 4K RPM.
Above that the ECU is speed/density mapping & the S-AFC can't adjust above 100%.
My work-around was to use a Cosmo AFM so I could use the S-AFC at higher flow rates.
Otherwise you're looking for a stand alone.
(edit)
I just realized you have an S4.
You could tighten the spring on the AFM & re-tune the S-AFC.
Old Mar 19, 2007 | 09:16 AM
J-Rat's Avatar
Alcohol Fueled!
Even with 100 Octane, you are out side the efficiency range of that turbo. Keep up the 13.x AFRs too much longer and Turrentine will be revisiting the inside of your motor. Why would you have such an aggressive motor built just to run it on a stock ecu with an SAFC?
A good rule of thumb is, if you add more fuel, yet your AFRs continue to decline, you are out of injector or fuel pressure/volume.
Okay, that takes care of the fuel volume part of the equation. And it wont richen up. Just because the boost falls off at high Revs, doesnt mean your fuel requirements will fall accordingly.
Hailers disproved this years ago. He saw 99% on his cycles with just a stock ECU using a type of multimeter thats designed to measure this type of thing.
Get a hold of that boost.. PRONTO!
Old Mar 19, 2007 | 09:20 AM
J-Rat's Avatar
Alcohol Fueled!
Its only "speed density" so much as it may correct up to about 8 ish psi or so. This also assumes that we have a MAP sensor, which in the truer sense, we dont.
Old Mar 21, 2007 | 02:20 PM
SureShot's Avatar
My stock pressure sensor on the 91 had a 2 bar range.
It would give a linear reading from -14 to + 14 PSI.
I had the blue wire from the S-AFC hooked up to it so I could monitor and plot manifold pressure.
Old Mar 21, 2007 | 02:25 PM
J-Rat's Avatar
Alcohol Fueled!
In order for the car to be SPEED DENSITY, it would have NO AFM. Speed density relies solely on MAP inputs to interpolate a point on the look up table..
Speed Density systems accept input from sensors that measure engine speed (in rpm) and load (manifold vacuum in kPa), then the computer calculates airflow requirements by referring to a much larger (in comparison to an N Alpha system) preprogrammed lookup table, a map of thousands of values that equates to the engine’s volumetric efficiency (VE) under varying conditions of throttle position and engine speed. Engine rpm is provided via a tach signal, while vacuum is transmitted via an intake manifold-mounted Manifold Air Pressure (MAP) sensor. Since air density changes with air temperature, an intake manifold-mounted sensor is also used.
Because a Speed Density system still has no sensors that directly measure engine airflow, all the fuel mapping points must be preprogrammed, so any significant change to the engine that alters its VE requires reprogramming the computer
Source: http://www.carcraft.com/techarticles...uel_injection/
Old Mar 21, 2007 | 02:36 PM
SureShot's Avatar
From what I observed with the stock AFM on my mildly modified setup, the AFM would hit 100% before 5K at WOT & 11PSI.
The stock ECU was just "winging it" above that. (A scary feeling)
Whatever the default map was, it kept increasing fuel to 8K.
I didn't like flying blind, so I swapped to the Cosmo AFM.
It was crude, but effective.
Old Mar 21, 2007 | 04:46 PM
J-Rat's Avatar
Alcohol Fueled!
But its still not speed density.
Old Mar 21, 2007 | 08:45 PM
arghx's Avatar
rotorhead
The turbo's coming out this weekend and then I am taking it to a shop to get the wastegate ported further.
and let it be known that I only discovered this problem recently when I got my wideband working (bought one and it was defective, and spent months hassling with customer service people). The boost creep really only got bad when it got cold outside. Last summer and fall it would hit like 10-11psi.
I probably won't get the standalone in until this summer.
Old Mar 22, 2007 | 01:21 PM
SureShot's Avatar
For sure it was getting more fuel as the revs went up.
I have never seen or tested if the pressure was factored in that corner of the ECU tables.
In the end I was getting ~300HP from 720 secondaries with a rewired 255LPH pump & an S-AFC with a Cosmo AFM, stock turbo, ported WG, MBC set to ~11PSI.
O yea - - & that big header dump, street port, beveled rotors.
Bottom line - the 720s were enough.
immanuel__7
89
Sep 5, 2015 10:23 AM
Snook
Aug 15, 2015 08:18 AM
