Shifter all over the place
Old Mar 18, 2007 | 12:21 AM
SaabGuy's Avatar
My newly purchased 89 t2 has a crappy shifting problem.
The shifter is loose as a goose and slops all over the place. Its pretty tough finding gears, and downshifting from 5th to 4th doesnt work unless I go from 5th to 3rd then to 4th. I can litterally move the shifter about 6 inches in all directions when I have the clutch pressed down.
Shifter bushings or (eek) something else?
Old Mar 18, 2007 | 12:32 AM
beefhole's Avatar
Boosted. I got BLOWN!!!
Probably the bushings. Is it an after market shifter? I had one in my car and the previous owner didn't install it correctly and it was totally FUBAR.
Old Mar 18, 2007 | 12:43 AM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by SaabGuy
Shifter bushings...?
Usually.
http://www.mazdatrix.com/faq/shiftbsh.htm
Old Mar 18, 2007 | 12:44 AM
Jager's Avatar
Tear you apart
It's most likely the bushings. It's a common thing on all RX-7's of this generation. Anyhow, just replace them and you'll be fine.
Old Mar 18, 2007 | 11:15 AM
SaabGuy's Avatar
Perfect! Thank you guys
Old Mar 18, 2007 | 11:23 AM
TwilightRotary's Avatar
i was having this problem too, this'll help alot.
Old Mar 19, 2007 | 08:27 PM
SaabGuy's Avatar
Looks like I'm completely missing this bushing:
http://www.mazdatrix.com/getprice.as...m=17-46Y0-M510
Has anyone replaced just the bushing or does the whole thing need to be changed?
Old Mar 19, 2007 | 08:31 PM
Turbo II's Avatar
It's only Rock and Roll
As cheap as they are replace them all.
Old Mar 20, 2007 | 12:43 PM
helghast7's Avatar
F yo couch!
hey thanks you solved the last proble i had with my car...although i dont have 6 inches worth of play mine has about 2 inches so i probably need to tighten it replace the bushings or its in wrong (not my fault its the previous owners fault).......by the way how much can i get a decent street clutch kit (you know with the bearing pressure plate and flywheel) my bearing is going and i figured i'd replace the whole thing?
oh yea and sorry for semi jacking this thread (only semi because it still involves trans)
Old Mar 20, 2007 | 01:38 PM
88turbotime's Avatar
I'd hit it.
+1 and then get a miata short shifter for cheap on ebay.
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
23Racer
Race Car Tech
Sep 21, 2015 10:48 AM
23Racer
Canadian Forum
Sep 18, 2015 11:10 AM
