External Wastegate's
Old Mar 16, 2007 | 11:29 PM
battle cattle's Avatar
Overboostin MoFo
Well after an exhaustive search I need some advice I haven't come across. I am currently running a oversized turbo I wish I could be more specific but I can't since the person I bought the car from had no idea what he put on. Currently I am running a 40mm HKS knockoff. Now its boost creeping on my **** so I know I need to upgrade to a bigger or better wastegate. Now after searching the tial website I saw something I haven't noticed which is a "rotary" wastegate. Now is this going to be better or just a more expensive wastegate? I guess I am really looking for advice from people making power. Also i don't really want to have to upgrade after this if I want to make more power. Any suggestions?
thanks
Josh
Old Mar 16, 2007 | 11:31 PM
J-Rat's Avatar
Alcohol Fueled!
I had not seen that. I am running the TiAL 46 mm on my car and it does NOT creep. TiAL in my opinion makes the best stuff out there.
Old Mar 16, 2007 | 11:44 PM
Overboostin MoFo
I am guessing your referring to this one
http://www.tialsport.com/prod_wg_46.htm
it says for the turbo rotary applications
Old Mar 16, 2007 | 11:46 PM
J-Rat's Avatar
Alcohol Fueled!
That would be the one!
Old Mar 16, 2007 | 11:48 PM
Boost Lee's Avatar
Dark Lord of the Drift
I'm running a teeny greddy wastegate, and I'm having no problems maintaining as little as 7psi.
Old Mar 16, 2007 | 11:50 PM
J-Rat's Avatar
Alcohol Fueled!
Well, that depends on your turbo.
Old Mar 16, 2007 | 11:57 PM
Overboostin MoFo
kinda a side note... does your turbo glow after a spirited run? Which might be part of my wastegate issue getting WAY to hot.
Old Mar 16, 2007 | 11:58 PM
J-Rat's Avatar
Alcohol Fueled!
Yeah, it glows a little. Depends on your definition of "spirited"/
Old Mar 17, 2007 | 12:01 AM
Overboostin MoFo
flirting with "redline" for 10mins in full boost/boost creep. My turbo goes full red and starts going down to the vclamp to the downpipe. Maybe I have another issue?
Old Mar 17, 2007 | 02:40 AM
FrankV702's Avatar
You better be careful with it creeping like that.. What other mods are done to your car? How much are you boosting??
Old Mar 17, 2007 | 03:43 AM
rx-7fc's Avatar
you have to check the sping inside may be put a smaller one and glowing can be from timing or fuel
Old Mar 17, 2007 | 09:55 AM
Overboostin MoFo
its only creeping to 12psi. Yes my car has most of the other mods to support more boost. Minus a new IC and a stand alone. 85% of the time I am pedaling it to stay low in boost.
Old Mar 17, 2007 | 10:03 AM
88rxn/a's Avatar
tom port.. AKA streetport
46 Mm Tial !!!
Ftw!
Old Mar 17, 2007 | 10:05 AM
Overboostin MoFo
sounds like the best of the best now to just buy it. Any suggestions on where to get it?
Old Mar 17, 2007 | 10:07 AM
88rxn/a's Avatar
i just found a GREAT deal here on the forum. less than half the price man!
keep an eye out or post wanting one. who knows, you may get lucky.
Old Mar 17, 2007 | 10:33 AM
Overboostin MoFo
I would love to do that but... i need to have one by friday and installed by saturday or earlier...
Old Mar 23, 2007 | 11:18 AM
Overboostin MoFo
Ok so I received my 46mm Tial Today and am going to install it but it seems that I might be missing a inlet gasket between the manifold and the wastegate. Is that something I don't need since I haven't found anything on Tial's website reguarding a gasket and before I go installing it I want to see if anyone knows the answer.
Old Mar 23, 2007 | 11:24 AM
Turblown's Avatar
Turn up the boost
Tial just released a 60mm fyi. What turbine a/r do you have, and what exhaust manifold?
Rotary Performance Parts
Old Mar 23, 2007 | 11:26 AM
Overboostin MoFo
yea just found out my manifold wont work... So I need one of those too... blah this is turning into something I dont need right now.
Old Mar 23, 2007 | 11:35 AM
Overboostin MoFo
1revvin7 ya busy a work??? I need to get this stuff taken care of soon anyway I can give ya a call to work it out?
Old Mar 23, 2007 | 01:20 PM
Overboostin MoFo
after some research.... I might have to make an adapter from the HKS to the Tial. But am I feel if I am missing a gasket/shim the 2 pics below are the HKS version with the gasket and the Tial without. Am I missing the gasket? Or dont you need one?
Attached Thumbnails External Wastegate's-p1030726.jpg   External Wastegate's-p1030727.jpg
Old Mar 23, 2007 | 06:23 PM
Turblown's Avatar
Turn up the boost
Looks like your missing a gasket on your Tial unit. I see the valve see, discharge flange and two gaskets for the discharge, but not one for the inlet...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
