help fuel problem!!!!!!!
Old Mar 19, 2002 | 01:06 PM
Angry help fuel problem!!!!!!!
ok, i completely removed my intake...., after taking the primary injectors off, i noticed one of them was WET on the bottom..., figured it was leaking......., examined them all, put them back into the fuel rail, the only leak i could seem to find was the oring, and after i played with it , it seemed not to leak anywhere.......
now my question is this...
if i had bad injector grommets, or leaking orings, is it possible that the engine would have flooded due to either one of these 2 things leaking????, or is it more likely that i had an injector stuck open/ or leaking.....?????
while priming my fuel system, i jump the yellow test connector, and my fuel pump just keeps going, i can't seem to find a gas leak....., but the pump never shuts off, does the pump stop when fuel pressure is good?, or does it keep trying to pump anyway?
help would be appreciated....
Old Mar 19, 2002 | 01:24 PM
JohnL's Avatar
I highly doubt your flood problem was from a leaking o-ring or Grmmet. If you had a leaking O-ring you would smell the gas from under your hood and also could risk a fire. I think the fuel pump is alway running with the motor running, this provides positive pressure on the fuel lines at all times.
Old Mar 19, 2002 | 01:49 PM
well, before i did this i did smell gas at all times, and i could hear pressure leaking...., now i smell no gas, and hear no pressure.... but the car does not run.........., but i'm still waiting on gaskets and such from mazda....(it takes 3 weeks for them to get me intake gasket, bac gasket, and inject gromets and orings.........
Queppa
Nov 18, 2024 03:47 AM
Microtech
30
Apr 23, 2016 06:37 PM
alphawolff
Nov 17, 2015 05:57 PM
