West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
clear coat question
Old Mar 13, 2007 | 06:02 PM
NeedFD's Avatar
R. R. R.
clear coat question
Quick question
Is there a way to add more clear coat to a car without having to repaint the area?
For example, get a brand new car from the dealer, and you want to add more clear, is there a way to do this? Or do you have to repaint the whole car and add clear right after painting?
Old Mar 15, 2007 | 04:17 PM
pshaw118's Avatar
Assassin of feudal Chinoy
Any shop should be able to add another coat of clear. I can't see why they wouldn't be able to.
Old Mar 15, 2007 | 08:34 PM
insomniac's Avatar
They wouldn't because they're too busy staring at his Sig
Old Mar 15, 2007 | 08:51 PM
jay3's Avatar
yes. clear coat is basically just a seperate layer that protects the paint and gives it more of a glossy look. my buddy put a extra coat of clear coat on his brand new CF hood since the layer it comes with usually doesn't last long.
Old Mar 15, 2007 | 09:23 PM
1revn3rdgen's Avatar
Yup, you could just add more clear coats. You just have to sand the car with fine sand paper.
Old Mar 16, 2007 | 12:00 AM
NeedFD's Avatar
R. R. R.
wouldn't sanding down the paint give it that "scratched up" look? if you add more, then the clear coat would just add a layer of coat but wouldn't you still see the scratch marks?
Old Mar 16, 2007 | 12:03 AM
NeedFD's Avatar
R. R. R.
Yeah i'm aware of what it is, but once the product is finished and dried up, you cannot just add more clear as it'll chip off, neither will it stick to a smooth surface.
Clear coat itself won't add more gloss, you have to wetsand and then buff it out to make it glossy.
Old Mar 16, 2007 | 01:50 AM
No, you have to sand it, or else the clear wont stick. It's just like if your color sanding. I would sand it with 1000 grit before applying any clear coats or higher just to be on the safe side. At work i usually do it with 1000 grit.
Old Mar 16, 2007 | 12:01 PM
Alex Rodriguez's Avatar
MODERATOR
Veteran: Marine Corp
sand it with 1000 grit with water make sure you dont press just braze over the car, also keep in mind to go in a cross hatch pattern dont go with the lines of the car go in a angle
have the car prep before the clear goes on, after that sand down your clear coat with 1500 grit then 2000grit with water again , then use 3m polishing compound and buff your clear coat back out
The reason you sand again after your clear has been layed is because you get that orange peel look if u dont, wetsanding the car after clear helps to smooth out the clear coat thus creating that super gloss look
Old Mar 16, 2007 | 12:11 PM
NeedFD's Avatar
R. R. R.
1revn3rdgen and El Nene 7
Thanks a lot, those are the exact answers I've been looking for!
Old Mar 16, 2007 | 03:54 PM
pshaw118's Avatar
Is homey gonna do it himself? I'd love to see some pics if he does.
Old Mar 16, 2007 | 09:22 PM
You could just sand it down with 2000 grit to buff it. If this is your first time buffing, i dont suggest you do it, you should get someone that knows how to buff.
tiger18
Sep 3, 2015 08:27 PM
