hey what brake fluid do you recomend?
what brake fluid do you guys recommend? I have a 93 fd and drive it mostly on the street and occasional auto-x. i hear the higher the DOT number the better...is this true? ansd does this mean you have to change it more often?? thanks alot -Jeff
no dot 5...dot 5.1 is ok
top pics for almost everone will prob be motul 600
or ate super blue
i run ate great ****..makes pedal feel like a rock and best of all its blue so when your fluching you knwo when its flushed clean...
http://www.bavarianautosport.com/shop.asp
its under brakes
or ate super blue
its under brakes
Yeah, like Bacon said, Motul and ATE are considered the best. The only thing you have to remember is these fluids tend to absorb water easier so you should change them once a year.
The best deal in brake fluid is those 32oz bottles of Valvoline SynPower that you can get at any auto parts store for $5. It isn't great fluid, but it is the best stuff you'll find on the shelf and it is dirt cheap.
-Max
-Max
alphawolff
Nov 17, 2015 05:57 PM
-Jeff
