13b bridgeported single turbo'd motor??
Old Mar 7, 2007 | 02:19 PM
K1HKSarse's Avatar
United Kingdom
I am building a circuit car here in the UK and im trying to find out if a fully bridgeported 13b running a single turbo would be good for track(circuit) racing.
What size of turbo would be suitable for approx 400rwhp? At what boost would you make approx 400rwhp on a full bridge and would there be lots of lag making the car uncompetative?
Also can anyone that has a fully bridgeported 13b running a single turbo measure their exhaust db reading please.
It needs to be below 103db to pass most noise levels for the track,some tracks are 98db limit here in UK !!!!!!!!!
I know it will depend on exhaust make/diameter and silencers so can you also post your exhaust makes and models.
Thanks
Gary
Old Mar 7, 2007 | 02:28 PM
olyrx7's Avatar
For the track I really suggest a street or race ported motor with a gt35r. The spool will be quick, decible reading will be reasonable, and you will be around 400whp if not more at 14psi.
Old Mar 8, 2007 | 03:40 PM
darkphantom's Avatar
The king of the highway!
your going to be all over the place. that bridgeport motor is going to spool the single turbo alot faster than a street port. but that bridgeport and a single is made for eachother. Considering that a bridge port makes its power between 4300-8500rpm and the single turbo doesnt usually spool until 3-5000rpm (depending on the turbo)
and since its going to be a circut car your going to be in the high rpms consitently
although i went from a half bridge to a street port cause i do autox and its my daily driver. but with the half bridge i couldnt stand the brap brap brap noise, the gas mileage, and the half bridge is a little louder than the street
Old Mar 8, 2007 | 05:20 PM
No_Rotor_RX7's Avatar
one of our customers we did a full bridgeport w/ a To4s XS engineering kit. he was over 400rwhp at around 13psi i believe. the car is wonderful on the road course being that his power band is wide spread... 4k - whenever he feels like lifting hahaha!
i have some video i'll try to post. either way if it's a track car only... do the bridgeport. mind you, our idea of a bridgeport is different than others. we have large cuts and bevel the rotor housing as well.
also, i'll post an update as we are currently putting on the new A-spec 600r turbo on this car. Should be bad ***
Old Mar 9, 2007 | 02:44 AM
K1HKSarse's Avatar
United Kingdom
Thanks guys for the replies so far.
The engine that i am looking at has 3mm PTS seals,has been pinned/dowelled.Are these seals good for circuit racing?They seem to be proven alot more in drag racing setups??
Old Mar 9, 2007 | 03:02 AM
jantore's Avatar
Talk to Pip at WGT Auto Developments, he's located in Middlewich, Cheshire, close to Manchester. And he has many years for experience building rotary race car engines.
http://www.wgtautodevelopments.co.uk/
Talk to him, and he even might be able to give u a good deal on a finished engine, and tuning of the engine.
JT
sherff
Feb 24, 2019 12:09 PM
JZW
20B Forum
Aug 18, 2015 08:56 PM
