which sub/amp setup?
Old Mar 5, 2007 | 09:25 PM
sLoW'n'StEaDy's Avatar
which do you think would be best? They will all cost pretty much the same price +/- $15
I am looking more for SPL than SQL. im thinkin #3 would give me pretty decent SPL and SQL, but am not sure about cancelation and what not.
1. 2) 10" subs running at 1000W RMS @ 1ohm
2. 3) 10" subs running at 1000W RMS @ 2ohm
3. 2) 10" subs and one 15" sub running at 1000W RMS @ 2ohm
now heres the storie. I have 2 of the 10" subs already. I can either buy a 1000W RMS @ 1ohm amp and just run the two 10's. Or for the same price i can buy a 1000W RMS @ 2ohm amp and either another 10" or a 15" sub. I know 10"s can hit pretty well and get the higher notes much better whereas 15"s hit the low notes like no ones business but cant really get the highs all that well.
Old Mar 5, 2007 | 11:49 PM
bigcox_03's Avatar
what brand and model are the subs? what brand and model are the amps that you are looking at? do the subs have dual voice coils? what impedenance are the voice coils on the subs?
Old Mar 6, 2007 | 07:31 AM
subs: POWFX10W 1600max 800rms
dual 4ohm voice coil
amps: MA Audio HK1000D (if i go with #1)
MA Audio M1900XE (for 2 ohms)
Old Mar 6, 2007 | 12:00 PM
bigcox_03's Avatar
how are you going to wire the subs? in series or parallel?
Old Mar 6, 2007 | 04:13 PM
parallel
Old Mar 6, 2007 | 06:40 PM
bigcox_03's Avatar
to keep your system simple enough you should go with your first combination of 2 dvc 4ohm subs wired in parallel to the 1ohm class d amp. that will be your best option. plus off the top of my head i dont think you can wire 3 dvc 4ohm subs into a 2ohm load. your best sound quality should come from option 1.
eplusz
15
Oct 7, 2015 04:04 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
