West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Check engine light bypass
Old Mar 5, 2007 | 04:43 PM
drugblock12a's Avatar
WON'T FORGET DAVE
Okay the time has come up for the wifes car to smog and the numbers are fine except the check engine light is on. Normally I would check it out and get rid of it the right way but work is killing me and I have no days off for the next two weeks. So someone please tell me how to bypass this. There's gotta be a way around this. Where I grew up they didn't care what light was on as long the numbers were low enough.
Old Mar 6, 2007 | 11:19 AM
SERIES7's Avatar
Embassador to SOY
What kinda car n00b?
Old Mar 6, 2007 | 07:07 PM
WON'T FORGET DAVE
95 benz s420. Yes I am a noob. Back home there isn't this kinda hassle with the smog.
Old Mar 6, 2007 | 09:25 PM
DCrosby's Avatar
No it's not Turbo'd
Just a thought, on the FD I'd pull the dash and disconnect the bulb... but from what I hear you have to have it on when you turn the key for 2 sec. and then go off... when the motor runs... which could be replicated with a simple timer circuit, but from the sound of you electrical prowice... I'd say that's not exactly trivial...
Old Mar 7, 2007 | 05:57 AM
pshaw118's Avatar
Assassin of feudal Chinoy
can't you just reset your ECU by shorting one of your fuses? it should keep the engine light off long enough to pass smog. Either way, try resetting your ECU before trying anything else.
Old Mar 7, 2007 | 09:00 AM
WON'T FORGET DAVE
I will try resetting the ecu for now. Hope that works.
Old Mar 7, 2007 | 09:50 AM
Siraniko's Avatar
RX for fun
Just PM DJDino for smog hook-up and be done with it.
Old Mar 7, 2007 | 10:17 AM
GOOFYROTOR's Avatar
cams pistons valves
pppmmmm'ed jooooooooo........................................ ............ phuc!
Old Mar 7, 2007 | 11:16 PM
SERIES7's Avatar
Embassador to SOY
Thanks again Goofyrotor for that smog hookup.
Old Mar 8, 2007 | 08:58 AM
GOOFYROTOR's Avatar
cams pistons valves
NO...........Thank you for that nice head job you did on me.
Old Mar 8, 2007 | 09:24 AM
Siraniko's Avatar
RX for fun
thanks Goofy for giving me a no-teeth job.
Old Mar 8, 2007 | 10:24 AM
GOOFYROTOR's Avatar
cams pistons valves
anytime Wacko! ......................................i'll pull your teeth out anytime, if it grows back again.
oh,......................thanks again, Slurpy.
Kyo
Apr 13, 2019 09:24 AM
elfking
Aug 19, 2015 09:48 PM
fastsaab
Aug 19, 2015 11:42 AM
