Dyno Tuned RX
Old Mar 5, 2007 | 12:27 AM
idsigloo's Avatar
Needs more Displacement.
Dyno Tuned RX
Ya... so went down to BG and dynoed at Horsepower House and was tuned by Jacob Cartmill himself. Here's the dyno results. We could of squeezed more out but ran out of time because I believe spark plugs on rotaries should last more than 4 months.
Forgive cell phone picture quality. I'll scan it later tonight so it's clearer.
3/3/07 11:25:19a Run Conditions: 65.66F, 29.46 in-Hg, Humidity: 14%, SAE: 0.98
Max Power = 229.37 Max Torque = 226.54
13psi
i think 16* advance 11* split
30 minutes of tuning
we were trying for 250whp@15psi, but ran out of dyno time.
their wideband was reading 1 point leaner than my PLX (which is in the downpipe) so thats what i was reading off of. the graph says it got up to ~12.5:1 at one point, but the leanest it got was ~11.5:1
Stock S5 Turbo
Full RB Exhaust
Stock TMIC
Old Mar 5, 2007 | 08:44 AM
pp13bnos's Avatar
Pineapple Racer
What kind of fuel where you running? CJ
Old Mar 5, 2007 | 10:09 AM
idsigloo's Avatar
Just 93.
Old Mar 5, 2007 | 01:08 PM
dubulup's Avatar
development
is this a stock TII turbo?
Old Mar 5, 2007 | 05:39 PM
idsigloo's Avatar
stock s5
Old Mar 5, 2007 | 08:09 PM
pp13bnos's Avatar
Pineapple Racer
Reason why I asked was because I'm running around 15-16 of timing with about a -4* timing on trailing while running 110 Sunco in my FD, at that boost. While its conservative for me, I was just curious what other people where running. CJ
Old Mar 6, 2007 | 12:06 AM
jacobcartmill's Avatar
just dont care.
4* split is pretty aggressive, but you're on racegas so i'm sure its fine.
Old Mar 6, 2007 | 12:38 AM
pp13bnos's Avatar
Pineapple Racer
No, I meant -4 timing. So the split would be like around 19 degrees. I've thought about putting some more trailing timing into it, but don't realy know how much is safe. CJ
Actually, I'm running about 15psi. I thought he too was....but after re-reading it, I notice that he's only running 13.
Old Mar 6, 2007 | 12:57 AM
idsigloo's Avatar
I have 11* split at 13psi and when I up the boost the next time I tune I'll probably have the split at 12* for 15psi. Stock is 15*, you should lower that atleast to 15* and see the difference. I'm just running 93 octane with premix, nothing special.
Old Mar 6, 2007 | 04:01 PM
Eggie's Avatar
Falls off pretty fast for a streetport. How much boost did it hold at 7k?
Old Mar 6, 2007 | 04:19 PM
zinx's Avatar
_________________________
Thats probably just the stock turbo not able to keep up.
Old Mar 6, 2007 | 06:17 PM
idsigloo's Avatar
Bingo. About 7psi at 7k I'd say, possibly less.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Rotate86
May 18, 2018 02:44 PM
Andrew7dg
Aug 6, 2017 01:41 PM
demetlaw
Oct 2, 2015 06:22 PM
