Should i get an Intake or a boost controller for next mod?
Old Mar 18, 2002 | 08:51 AM
SilverFlash's Avatar
Question Should i get an Intake or a boost controller for next mod?
Well i've been having a boost problem on the primary,and i can only get it up to 7 lbs and i've had a rotary mechanic check for a boost leak and he said there is not a leak.He thinks if i get a boost controller i'd be able to control it and,he thinks that my ECU is making it go to a safe boost level since i have a straight thru exhaust. I did the airbox mod and it's better than before,but i'm sure it's not as good as a after markek intake. I can only afford to get one or the other,so what do think i should get. I would like to get 10 lbs boost,but the stock intake sucks!
Old Mar 18, 2002 | 09:15 AM
Rotary Master
You have a problem somewheres, don't make it worse by adding either one. Take your car to Pettit or N-tech and have them take a look at it. You need to find the problem.
Old Mar 18, 2002 | 09:52 AM
Mahjik's Avatar
Mr. Links
Exclamation
What are all the mods that you currently have on the car?
I agree with Johnsrx7, you have something else going on... The stock air box may suck, but it won't keep you from getting 10 lbs of boost. Time to change mechanics!
Old Mar 18, 2002 | 09:58 AM
ttpowerd's Avatar
HARRRRRRRRR
so true, find you problem b4 creating new ones
Old Mar 18, 2002 | 10:24 AM
Bucrx7's Avatar
Re: Should i get an Intake or a boost controller for next mod?
If your rotary mechanic told you to add a boost controller so that you can turn up the boost to 10lbs then I wouldn't trust him as a "rotary mechanic". There has got to be a problem some where if it's not reaching 10lbs on your secondary. What's the max boost you reach on your primary? If the ecu is in the "safe" mode then it would bog if you reach 1 or 2 psi.
Old Mar 18, 2002 | 02:58 PM
I'm getting 7 lbs on primary and 10 -11 on secondary.I have a downpipe ,custom midpipe and greddy PE exhaust. Then airbox mod and HKS PFC FCON for fuel management. My vacuum is 18. I think i'm gonna take it to another mechanic thursday.
Old Mar 19, 2002 | 01:56 AM
rynberg's Avatar
Sounds like you could be missing the pill to the wastegate or your wastegate isn't attached to the actuator. With those mods, I think you would be hitting 13-14 psi.
cristoDathird
28
May 30, 2019 08:47 PM
