Megasquirt Built a copy of the V3.0 build up... need ignition help
Old Feb 25, 2007 | 02:57 PM
KamakazieX's Avatar
I have removed my stock wiring harness. I have everything wired up but the ignition. Igs-t Igt-t and Igt-s... can someone circle or draw on a digital pic of the engine bay and show me what I am wiring up since my harness is gone?.
Thanks for whoever can help.
-Matt
Old Feb 26, 2007 | 12:57 PM
dpf22's Avatar
If you find a version of the factory service manual, then it will tell you the wire colors of those wires on the coils themselves. All of the wires on the leading coil are used, and all but one of the wires on the trailing coil are used. I believe if I am not mistaken, the blue/red wire is the one not used, but I could be wrong. Only way to do it right is to get yourself a set of good wiring diagrams and figure out the correct wire colors. Yes, they are the same colors on the coil itself. Also, I believe the faq has actually got the wire colors you are supposed to splice into.
dpf22
SakeBomb Garage
Vendor Classifieds
Sep 7, 2015 03:44 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
