stumbling
Old Mar 16, 2002 | 08:37 PM
journey's Avatar
stumbling
I was driving my car today(89 RX-7 GXL) and it stumbled between 3k and 3.5k. Never happened in the higher gears, just 1st and 2nd. By stumble i mean like when someone learns to drive a clutch the first time, and the car shudders a bit, that kind of thing.
The car is totaly stock right now, only had it less than a month. What kinds of things should i look at? I should mention it didn't always do this btw, i got past the trouble range a few times with no problems, also it stumbled once at about 2.5k i think. Only planned maintinence right now is just replacing spark plugs, wires, oil, and oil filter next weekend, should i expect to need to do more to fix this problem(its only happened today btw, on my way home and i havent driven it since then, a little worried). The check engine light does come on momentarily, while its stumbling. Doesn't stay very long though i didn't even notice the first few times.
Any help appreciated, thanks
Journey
Old Mar 16, 2002 | 08:41 PM
rico05's Avatar
WTB S5 N/A FC
Might be a bad grond to the coils. I know when my trailing coil was not grounded well, it would stumble, and the engine light would come on. Check those grounds!!
Old Mar 17, 2002 | 12:02 AM
deadof_knight's Avatar
hmm i have stumbling myslef
it seems ok in wot but its the cruise speed that stumbles or at an idle its like its popping Im gonnna check the coils grounding and then onto the tps sensor anything else i need to look at ?
rgordon1979
40
Mar 15, 2022 12:04 PM
alphawolff
Nov 17, 2015 05:57 PM
Jmolina0163
19
Sep 25, 2015 06:06 PM
R7rexy
19
Sep 2, 2015 10:24 AM
Kruel13
Aug 26, 2015 12:17 PM
