Suspension problem.
Old Mar 16, 2002 | 08:19 PM
RexTech's Avatar
Suspension problem.
I have stock wheels, tires and shocks.
Since 14000 miles ago eibach springs were installed.
I have noticed -since 3000 ago- that the front tires are rubbing against the fender in turns at not so hard driving.
What is bad in my car.
Thanks for your help.
RT.
Old Mar 17, 2002 | 10:04 AM
RexTech's Avatar
I took the left front shock & spring out and everything seems to be ok. The mounting rubber is like new. The only part damaged is the shock bound stopper.
Do you now how thin is the insulator? I have just a plastic paper.
Any sugestion?
Old Mar 17, 2002 | 04:33 PM
ZoomZoom's Avatar
SEMI-PRO
depending on the tire size your running and the amount of drop the springs gave you there might not be anything wrong with your car.
Postman09
Sep 29, 2015 11:23 AM
