Springs and tires for Auto X
Old Feb 16, 2007 | 12:44 PM
Unseen24-7's Avatar
Card-carrying Rotorhead
I will be looking for a good set of performance springs for Auto X this summer and i was wondering what would be good springs?
looking to spend $300-$500 (roughly)
Preferably NO lowering, but no more than 1.5".
as for tires I would like something that would fit on the stock 15" rim. At first i was considering Bridgestone Potenzas until i found out that they don't fit the stock rim. Any other suggestions?
oh yeah and Asenzis are out, auto x in my area considers those R-compund and i wanna stay street.
Old Feb 16, 2007 | 03:20 PM
Richter12x2's Avatar
Taste great, more filling
This is probably best for the Suspension or Racing sections of the site - I use a Ground Control coilover setup with Eibach ERS springs - the kit for all 4 corners is around $400 ish, and you can customize your spring rates within reason - I think I did 440# fronts and 300# rears - if you plan to drive it, you may want to go a little softer. The Ground Control setup is height adjustable, but don't let them talk you into the 7" rear - I'm pretty sure you want 6" front and 8" rear -
please someone correct me if I'm wrong -
Ground Control has somewhere in some computer that 6" front and 7" rear is what works for the 2nd Gen RX7 - and it does, but only if you dial the front all the way down and the rear all the way up - otherwise you drive around looking like you're always launching hard.
I use Kumho Ecsta 711's, but they just discontinued those. Grassroots Motorsports (I think Grassrootsmotorsports.com is the site) did a huge writeup comparing tires, and like you said the Azenis were way up there, but there were 2 or 3 others that were close.
Old Feb 16, 2007 | 03:23 PM
Rexpelagi's Avatar
53.6%/46.4% - Crap!
I used GC/Eibach on another car I had. I loved the simple setup and the handling was unmatched even with some of the expensive coilovers people ran. Never tried them on the 7, but I am assuming they would be awesome on this platform as well.
Old Feb 16, 2007 | 04:57 PM
jpd3253's Avatar
You might take a look at the BFGoodrich g-Force Sport, which come in 15" sizes.
http://www.tirerack.com/tires/tires....nSpeedRating=H
Took Bridgestone Potenzas off my 'vert for a set of the BFGoodrich g-Force Sport. Handling change was night and day. Just note they are summer tires.
Old Feb 19, 2007 | 12:33 PM
Unseen24-7's Avatar
the g-Force's are like 1/4 of the price of the potenzas and you say they're better?!?!? If that is true then that's likely what i'm gonna buy.
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
