exhaust header heat shield
Old Mar 16, 2002 | 10:02 AM
darkwaveboi's Avatar
Need donor car in Fairfax
hey,
Earlier i was askin about a rattling coming from under my car w/ the exhaust, and the plate which is loose is the one which sheilds the exhaust ports where the header connects to the engine (there is a sensor going into the exhaust header a bit below). Im wondering, are there any negative effects if i take it off because it IS rattling a LOT. will it effect the temp of the engine bay too much?
Thanks,
Jeff
Old Mar 16, 2002 | 10:06 AM
Silkworm's Avatar
Has been.. hangin' around
Um... Why don't you just tighten the shield?
Yes and no. The exhaust is very hot, much hotter than a boinger motor's exhaust. That's why they have shields running the entire length of the car. Your passenger';s feet will get very hot if you remove the shields. Dunno about heating the transmission, but all that heat isn't going to do your trans fluid any good.
PaulC
Old Mar 16, 2002 | 10:12 AM
i actually dont think that my car has the heat sheild under the pre/main cats, cuz you can see the cats. I looked at a FSM and it has a pic of a sheild going under the cats? mines a 91 na, w/ stock cats and all, should i have that shield under there?
Old Aug 28, 2002 | 11:02 AM
SoloIIdrift's Avatar
What about just removing the heat sheild on the manifold itself, everything back from the 02 sensor is still covered. Will this melt the silicone lines going to the 6 port actuators?
Old Aug 28, 2002 | 04:19 PM
anyone?
Old Aug 28, 2002 | 05:00 PM
rx-7s rock's Avatar
Game of Death
Just tighten the freakin shield and there won't be rattling. Don't remove the heat shields in any situation. Just a bad idea. It's not like the weigh much, and the exhaust is real hot, which is why the shields are there in the first place.
tonka_1956
Sep 2, 2015 05:55 PM
04G35S
Aug 14, 2015 07:31 AM
