sudden transmission failure
Old Mar 16, 2002 | 07:35 AM
nath's Avatar
Angry sudden transmission failure
Search feature down at my worst time. Just for no reason I can not move shifter into reverse. No problems with all forward gears. I plan to take car to a rotary speciality shop but would really like to know from someone in the group what you think has happened. It's as if the linkage has broken, not clutch or syncro problem.
Old Mar 16, 2002 | 08:10 AM
Try putting it in fourth first, and then try reverse. (No need to be gentle either show that transmission who da man!)
Old Mar 16, 2002 | 12:30 PM
RecKleSs's Avatar
Adrenaline
If you start having problems putting into the other gears, it most likely is your release bearing fork that needs to be replaced.
MILOS7
Oct 9, 2015 02:19 AM
rxlevi7
Sep 26, 2015 07:28 AM
