How to put engine at TDC
Old Mar 16, 2002 | 12:32 AM
Papasmurf's Avatar
How do I know how to do it, for lets say I am taking out my CAS. The search feature does not work.
Old Mar 16, 2002 | 02:05 AM
RETed's Avatar
There's a "raised pointer" on the outer, stationary shaft.&nbsp Align that with the dimple on the inner, spinning shaft.&nbsp Make sure to pop the cover off when inserting to keep track of the CAS, cause it WILL spin on you while inserting.&nbsp Keep track of one of the two prominent trigger gears, cause it'll be close to one of the magnets.
-Ted
Old Mar 16, 2002 | 02:32 AM
Papasmurf's Avatar
Thanks for the tip.
Old Mar 16, 2002 | 03:02 AM
Felix Wankel's Avatar
Super Newbie
If your marks are wrong (some people **** with the pulleys ), pull the rear rotor plugs and look for an apex seal to be across one of the plug holes.
Old Mar 16, 2002 | 04:48 PM
HAILERS's Avatar
HAILERS
Read the bottom of this article.http://www.teamfc3s.org/info/articles/demystifying.html
Th0m4s
Feb 26, 2019 02:04 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
20B Forum
Aug 19, 2015 01:47 PM
