3 MOD + 10PSI IS it ok without ECU?
Old Mar 15, 2002 | 08:32 PM
10 hours of back breaking nee bending I finally got
my boost back.
I changed whole vacuum line and I fixed the vaccum chamber and changed one check valve.
now my car flies.
also I put homedepot valve because one pill was missing
Now I wnat do some more mods.
first I want to do stock airbox mod.
I already have Catback and downpipe so It gona be my
3rd mod.
Ok I think I can control the boost with homedepot valve
If I keep stock boost pattern(10-8-10) will I be Ok?
I wanna buy ECU but I can't because I have to buy tires.
thanks.
Old Mar 15, 2002 | 08:41 PM
mjw's Avatar
mjw
I would hold back if I were you on that one, if you can't afford an ECU can you afford a new motor? Is it worth the extra 10HP at most you would get from the K&N drop-in filter? Go ahead and buy those new tires and have some fun with what you have, getting new tires is one of my favorite mods!
Matt
93 SSM
fluidyne, PFC, Nur-spec, 18in. Volk LE37K tomorrow!
Old Mar 15, 2002 | 08:42 PM
rynberg's Avatar
Why risk it for the few HP you'll gain from the airbox mod? Just wait until you can afford an ECU.
Old Mar 15, 2002 | 08:50 PM
mazdaspeed00's Avatar
For Sale
to answer your question you can safely run 10 psi on thoes mods. but there is always that risk of running too lean if for some reason your boost contoller fails.
Old Mar 15, 2002 | 10:15 PM
Pumped's Avatar
it should be ok, i had more mods than you and still had the stock ECU. kept it a 10 psi for a year and the car is still running strong with good compression.
i have a pettit unlimited now
Old Mar 15, 2002 | 10:46 PM
1FAST7's Avatar
yea, it should be ok. but, I would stay away from a 3rd mod. Save up some money for a ecu.
1FAST7
befarrer
Old School and Other Rotary
Oct 5, 2015 03:30 AM
ZacMan
Sep 19, 2015 09:20 PM
SCinfidel
Sep 8, 2015 05:36 PM
dillrx7
Sep 7, 2015 09:38 AM
