Redoin fd interior- how to remove green plastic blinker lenses
Old Feb 2, 2007 | 12:04 PM
Wrathritic's Avatar
I need to know how to remove the green blinker lenses on the main guage cluster peice, I am redoin the interior peaces with plasti-dip. How have you done it is there some chemical to use to get them off, how abouts did you put them back on, super glue?
Old Feb 2, 2007 | 05:38 PM
badddrx7's Avatar
All Spooled Up
GREEN BLINKER LENSES 101
They are melted into the cluster face from the factory. Simply take a small screwdriver and carefully pry up each side the break the bond. Tag each lenses for the side it came out of. After you are done, then add a small drop of superglue gel to where they were bonded on the cluster face and replace each one exactly as it came out. They will fall right back into the spots where they broke away from.
tom
Old Feb 3, 2007 | 02:30 AM
spandy's Avatar
Patience
I put masking tape in there and cut it out with an nt red dot knife.
Sorry, I'm a window tinter so you probably don't have a clue what I just said pertaining to that knife.
A hobby knife would would too, and then I just picked it back out with my blade.
risingsunroof82
Sep 7, 2015 01:11 PM
Apoc3D
Sep 5, 2015 10:24 AM
