Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
engine swap into 3rd gen, cost????
Old Jan 26, 2007 | 06:45 AM
sillyme's Avatar
i want a four cylinder motor. sr20det, f20c, etc etc. is this easy? is there a swap kit for four cylinder motor? how much would it cost to pay someone to do it not including parts? anyone know of a place? thanks
Old Jan 26, 2007 | 09:52 AM
90turbo1's Avatar
well thats a pretty open ended question.
It will cost you what ever it costs there is no real set in stone price.
if you do a SR20 DEt it whont be legal to emission here in washington state. why do you want a 4 cyl??????
just a thought a LS1 or a similar motor is about the same weight as the rotary and almost as small
so you will need to buy a motor $$
trans (maybee the rotary one will work) $$$
some fab work for the install $$$
electrical to make it work $$$$
if you want ac and all that stuff you will need custom lines for the pump for the motor you swap in.$$$
depending on the motor you choose the hood might not fit, 4 cyl motors are sometimes higher due to the straight up and down mounting of them.
possible custom drive shaft.$$$
ever thought about a VG30DETT grannys sells a kit to install that motor that would be cool and you can pick up a 300ZX for not too much these days if they are wrecked..
later
just a thought.
astrum
24
Nov 15, 2017 08:44 AM
