MoTeC My *Official* Motec M2R Thread
At first I was leaning towards the Haltech E6X, but after talking with a few people about the motec, I decided it was a better route in the long run. Especailly since discovering the Motec M2R. Damn Aussies are crazy for rotories, but that's good with me!
The M2R was priced similarly to the E6X, so after seeing a demo of both systems, Motec was an easy choice.
I decided to start this post to document and address any issues or joys I have with my new ECU.
So, some basic info to start off:
87 Turbo II
Engine Build by Elliot at Turblown.net
S5 Turbo (for now) ported wastegate
Detail on Engine Here
Just wanted to introduce myself and car to the Engine Management Forum.
87 Turbo II
I am not posting price info here. If you are in the market for a e6x, you can call motec and see if its worth the extra money.
I read through the manual to learn that you can tune this ecu remotely. This means that mu tuner could tune this car from his couch while watching CSI! Or the motec people in CA could tune the car from thier shop.
I know that aem has this feature, but am pretty sure the haltech doesn't.
Trending Topics
on
Originally Posted by Evil Aviator
Im am interested in you correcting the statements made by stylEmon.
Ok, here goes:
1st, on the other thread he mentioned something about entering inputs and building a map based off of that.. Not sure where that came from, possibly a misunderstanding of the use of closed loop wideband. The ecu should come with a quick setup file to get you going, but is not sophisticated enough to interpolate an entire map based off basic inputs.. The wideband lambda is an upgrade option that is available at an additional cost.
2nd, as stated on this thread regarding telemetry. Telemetry requires the use of an a separate link available from motec which allows you to remote monitor and datalog.
Originally Posted by RETed
You sure like to trash Haltech a lot...
Why don't you report back to us once you get the car running.
-Ted
-Ted
I have never used a haltech, although seen a few in action. Since haltech seems to be the most popular amoung my rx group, I will be comparing my experiences to what i know of the haltech.
I've heard that the software is more user friendly. Like, you can input conditions, specs on your car, and ideal output (hp or what have you) and it can create maps based on your input.
2a+RoN, thanks for the explaination of telemetry. I misunderstood the definition. it seems that you cannot tune it remotely, but rather view and log remotely.
on
Originally Posted by FDNewbie
1) Does it require a multiplier for ignition?
2) Can you run split timing?
Thanks,
~Ramy
Thanks,
~Ramy
2) Yes.
on
Originally Posted by charlies7
As far as tuning the ECU is it any harder that lets say the pfc or the haltech?? Sorry might be a dumb question. Could anyone that is very qualified tuning rotaries have a problem tuning this ecu??
Rotorhead
on
Originally Posted by stylEmon
I am still learning the system, and i post features once i learn about them. If you've misunderstood something, be more specific and give me a chance to correct it. thanks.
Optional Software Pricing as of current catalog (hardware not included):
$910 Telemetery (sends live info to laptop, does not receive tuning updates)
$910 Remote Logging (logs the telemetry info)
$190 512K Datalogging (after the free 6 hr tuning period)
$710 Enable Single Wideband Lambda (after the free 6 hr tuning period)
$1170 Enable Dual Wideband Lambda Option
I am not a vendor. All info above was taken from the Motec website. Just my 2 cents, but it's usually a good idea to do a little more research before buying something this expensive. I do agree that it looks like an excellent product so far.
Originally Posted by 2a+RoN
Ok, here goes:
Thanks,
~Ramy
Thanks,
~Ramy
on
not the M2R. The MX00 series ecu's use a windows based software. There is nothing wrong with the DOS software. It is much easier to use than the version 3 windows software for the other ecu's..
Also, EvilAviator, those prices are for options available to the MX00 series ecu's.
Rotorhead
on
$360 for Enable Single Widerange Lambda (LSM-11)
$475 for Advanced Tuning Features & Onboard Datalogging
No other options are listed for the M4 series. Hopefully they will address that issue in the next catalog.
i am still trying to figure out if the m2r falls in the MX00 series or the mX series. It seems to have some features from each.
I'm sorry wha?
The pure tunning potential of the Motec mx00 series ecu is worth the money. Though even I agree that charging for lambda upgrade is a bit silly and some of that other crap...but i have a feeling if you search hard enough you can probably find a crack for the softare/hardware truthfully...or if you ask a hacker nice enough I imagine he would do it, and do it quite well haha. I also like the fact that you can run 4 seperate coils for the 13b quite easily, instead of having to use the damned OEM ones that never seem to stack up when it comes to adding an ignition amp to them. Or how about being able to add even more injectors without having to get an auxiallary box to run em?
rebreaking things
on
"The M2R is based on the M4, which is a fairly old ECU. Its a good value for people with simple 2-rotor applications, but isn't in the same class as any of the newer, more powerful ECUs available on the market. Plus, once you add all the options you'd typically want such as Lambda and Logging, the value diminishes a bit.
Still, being a MOTEC, you know its a stable, well-designed unit which will make injecting the motors its designed for easy!"
