Stock oil pressure gauge
Old Mar 13, 2002 | 07:55 PM
FreedS4's Avatar
Is the stock oil pressure gauge accurate or should i get an aftermarket gauge? If so, what gauge should i get? I'm looking at a Auto meter gauge but it only reads to 100 psi, is that enough? Thanx for the help, sorry to be a bother
Chris
Old Mar 13, 2002 | 08:02 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Stock oil pressure gauge
The stock gauge isn't intended to be used to get accurate readings, it's only to give you an indication and isn't alot better than an idiot light (just better looking). Get an aftermarket one.
I'm looking at a Autometer gauge but it only reads to 100 psi, is that enough?
Plenty, unless you've modified the oiling system pressure shouldn't go much higher than about 70psi.
Old Mar 13, 2002 | 08:07 PM
FreedS4's Avatar
Thanx Jason
Old Mar 13, 2002 | 08:26 PM
RETed's Avatar
More info...
http://fc3s-pro.com/TECH/MODS/EL/opress.htm
-Ted
Old Mar 13, 2002 | 08:32 PM
FreedS4's Avatar
thanx ted
andyvideopro
Aug 20, 2015 10:55 AM
