Sponsored by: CARiD
Help Plz....
Old Mar 13, 2002 | 06:19 PM
RX-7 Turbo II's Avatar
Help Plz....
i have a question...for some reason my car does not want to start. when i turn the key all it does is make a noise like as if it is going to turn on but it does not. also my add coolant light goes on and my car does not need coolant.... can anyone help me
Old Mar 13, 2002 | 09:13 PM
JONSKI's Avatar
5yr member, joined 2001
Is the engine turning over? Did you not let it warm up to optimal operating temperature befure you shut it off again? If yes to both, then you might be flooded. Check your manual for the easy unflooding procedure. If that doesn't work, then you may need to do the pain in the *** unflooding procedure. You can search for it. The procedure has been posted many, many times.
Old Mar 15, 2002 | 07:04 PM
thnx man
new2mazda
16
Jan 14, 2008 09:21 AM
pippip
Aug 25, 2007 10:33 AM
