question on differentials
Old Jan 21, 2007 | 01:22 PM
iwantjdm's Avatar
I have a 1980 rx7, and I'm putting in a 85 gsl-se rear end. The only problem is that the ring gear and pinion gear on the gsl-se diff is broken.
The question I have is, Can I use the diff housing and ring gear from my 1980 with the gsl-se diff and axels? thanks
Mitch
Old Jan 21, 2007 | 01:25 PM
trochoid's Avatar
Old Fart Young at Heart
No. The axles and bearings are bigger and will not fir in the earlier rearend housings.
Old Jan 21, 2007 | 01:34 PM
iwantjdm's Avatar
ok thanks, would i be able to take the ring gear and pinion gear and use them in the gsl-se housing? sorry for all the questions.
Mitch
Old Jan 21, 2007 | 01:48 PM
trochoid's Avatar
Possibly, I'm not certain about that. I would remove the 3rd memebers as a complete unit, don't touch the pinion nut yet, then measure the R&Ps for comparission.
Old Jan 21, 2007 | 01:55 PM
iwantjdm's Avatar
yeah thats what i was planning to do, i just need to get my other car running first so i can take my time with this. thanks for the info
Mitch
Old Jan 21, 2007 | 02:08 PM
Siraniko's Avatar
RX for fun
RX-2, RX-3 SP, SA, FB, KIA sportage/ B2600 4x4 all have the short pinion shaft and same ring diameter. So using the R&P from your 79 should work on the GSL-SE 3rd member. You wont notice a big difference between a 3.90 and 4.10.
Old Jan 21, 2007 | 02:26 PM
iwantjdm's Avatar
cool thanks
_Tones_
May 25, 2021 05:37 AM
kkev.7788
West RX-7 Forum
Sep 2, 2015 02:13 AM
