How are these internals?
Old Jan 20, 2007 | 06:39 PM
mattreeve's Avatar
Could I use these Parts in a streetport Rebuild? Other than the obvious are these housing and other ok?
I see a little rust on one housing and one broken side seal?
Any input would be greatly appreciated.
Attached Thumbnails How are these internals?-rx7-engine-internals-005.jpg   How are these internals?-rx7-engine-internals-008.jpg   How are these internals?-rx7-engine-internals-012.jpg   How are these internals?-rx7-engine-internals-004.jpg   How are these internals?-rx7-engine-internals-006.jpg
Old Jan 20, 2007 | 06:42 PM
mattreeve's Avatar
heres another
the rust I was speaking of
Old Jan 20, 2007 | 07:18 PM
rbf41182gt's Avatar
that's not rust- the coating on the housing is flaking off. You can use it, but if you don't have to, I wouldn't. I was faced with a similar dillema when i rebuilt my engine, except my flaking was much worse so I replaced it. Yours doesn't appear to be too bad so you could use it if you wanted to.
Old Jan 20, 2007 | 07:24 PM
RX3SP's Avatar
Can't Hear Now
I would replace that rotor housing with the chrome flaking. Once it's flaking that much, it continues to get worse quickly.
Old Jan 20, 2007 | 07:36 PM
mattreeve's Avatar
Can they be repaired?
Old Jan 20, 2007 | 07:54 PM
rbf41182gt's Avatar
kind of
but it's not worth it
so...
no
Old Jan 20, 2007 | 09:08 PM
Dan_s_young's Avatar
Turbo widebody FB
Just remember quality of the rebuild directly effects the length of the rebuilds life.
When in doubt replace the part. It's more expensive but it's cheaper than having to tear it all appart and redo it in the near future because of cutting corners this time around.
Old Jan 21, 2007 | 02:09 PM
trochoid's Avatar
Old Fart Young at Heart
Housing is toast.
Old Jan 21, 2007 | 03:09 PM
mattreeve's Avatar
What Can be done to temorarily and cheaply to fix it any suggestions?
Old Jan 21, 2007 | 03:36 PM
Druken's Avatar
Nekurd
Damnit. So far the rear housing from the block im tearing down is flaking too.. hopefully the front housing is okay... arg
Old Jan 21, 2007 | 03:39 PM
rbf41182gt's Avatar
nothing
Old Jan 21, 2007 | 03:43 PM
defakto's Avatar
Looks like there might be some chatter marks too on that housing. Might as well replace it like everyone else mentioned abve.
Old Jan 21, 2007 | 03:51 PM
j9fd3s's Avatar
Community Builder
that housing will run, but it will always be lower on compression than a new housing, it also will not last as long as a new housing.
Old Jan 21, 2007 | 06:48 PM
mattreeve's Avatar
So what are the chance that the other engine I have thats running is in the same condition?
I further cleaned them And this is what I suggest doing, Use a wire brush to take off a oxidization, and fill with devcon steel; putty . Then smooth it out with fine sandpaper.
Old Jan 21, 2007 | 07:02 PM
rbf41182gt's Avatar
it's not going to work, it'll just flake off 10000X faster than the original coating.
I'm sorry i'm being so pessimistic, but it's the truth.
Old Jan 21, 2007 | 07:21 PM
blwfly's Avatar
kiwi from downunder..
the putty willl problaly come off and may reck the rotors
Old Jan 21, 2007 | 07:25 PM
trochoid's Avatar
I'll give you 50/50 odds that it doesn't make it through the 1st complete heat cycle and restart without having some damage.
Old Jan 21, 2007 | 08:04 PM
mattreeve's Avatar
So whats My "BEST" Plan of action? For a higher performance re-build.
Leave it alone hope nothing else happens?
Maybe some heavy grease will carbonize itself into the flaked areas?
Go to a shop that can re-surface that small section? If so what do I ask for?
Cheers
Matt
Old Jan 21, 2007 | 08:16 PM
rbf41182gt's Avatar
your BEST plan of action is to get a new one!!!!!!!!!!!
or a used one with NO FLAKING!!!!!!!!!
Old Jan 21, 2007 | 08:17 PM
mattreeve's Avatar
Money doese'nt grow on trees!!!!
Old Jan 21, 2007 | 08:24 PM
Latin270's Avatar
If your on a budget go ahead and use it.
Old Jan 21, 2007 | 08:34 PM
nick812's Avatar
13b P-port on a budget
If your on a budget you could use it but I wouldnt use stuck seals go with carbon or maybe RA or atkins. Use a softer seal.
Old Jan 21, 2007 | 08:43 PM
RX3SP's Avatar
Can't Hear Now
You are better off using that housing as is rather than trying to "repair" it using Devcon.
Old Jan 21, 2007 | 09:37 PM
rbf41182gt's Avatar
you can find a good used one for like $200.
and you can use it, just don't expect it to last for a long time.
Old Jan 22, 2007 | 01:51 AM
REVHED's Avatar
Hunting Skylines
What's the point of spending good money on a gasket set as well as hard seals if they're out of spec if you're gonna use a crap housing?
