Help or Eliminating Wheel hop
Old Mar 13, 2002 | 04:14 PM
Rotary93's Avatar
Retired RX7 mechanic
What have you guys done to help or eliminate wheel hop? Let me know what you have tried and what has worked...
Old Mar 13, 2002 | 04:23 PM
ttpowerd's Avatar
HARRRRRRRRR
deferintial bushings and m2 trailing arms......
try a search...this has been out there b4
Old Mar 13, 2002 | 04:40 PM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
jimlabs diff bushings helped my car.
Old Mar 13, 2002 | 06:08 PM
Rotary93's Avatar
Just the differential bushings or the whole set for the rear....
Old Mar 13, 2002 | 07:35 PM
Johnny's Avatar
OG
yup the diff (jim's) will do it...
The m2 stuff helps some also
Old Mar 28, 2002 | 07:22 AM
Rotary93's Avatar
Has anyone tried the Mazda Comp Diff bushings? Where can I get them?
I heard Jims diff bushings were too hard...
Old Mar 28, 2002 | 07:58 AM
mmaragos's Avatar
Too hard?
I have a '94 Touring and have a complete set of Unobtanium bushings installed. No way are they too hard. This is a performance car anyway, but I honestly did not notice any significant increase in ride harshness. Maybe my old bushings were just way worn, but I actually think that the ride is smoother than before. Meaning that when taking hot laps through twisties with bumps through turns, it feels very secure and ride comfort is at least equal. Wheel hop on drag type launches has almost been elminated, reduced by at least a factor of 10.
Old Mar 28, 2002 | 06:07 PM
justin's Avatar
I drag raced my car two times with horrible wheel hop and decided I could not run again until I cured the wheel hop. The pettit complete rear launch kit really helped me with the holeshot by almost eliminating wheel hop.An adjustible shock set to softest will also help along with the launch kit.
Old Mar 28, 2002 | 06:57 PM
Rotary93's Avatar
I just installed Pettit trailing arms...
Next to buy is the toe links...
I inspected the Toe links when I was under the car and found them to be very loose....I guess the rubber is worn out on them..
dillrx7
Sep 7, 2015 09:38 AM
Nosferatu
Sep 5, 2015 02:13 PM
ray green
1st Gen General Discussion
Sep 2, 2015 06:35 AM
