Help: Car floods and Stalls
Old Jan 17, 2007 | 05:20 PM
RX-7Tunner86's Avatar
HElp
i just got my car done i did a vert and it wont stop flooding i can get it to run but when it dies it takes a long time to get it back on plz help
Old Jan 17, 2007 | 05:22 PM
J-Rat's Avatar
Alcohol Fueled!
what exactly did you do to it?
Old Jan 17, 2007 | 05:23 PM
no mods just stock
Old Jan 17, 2007 | 05:33 PM
J-Rat's Avatar
Alcohol Fueled!
Well, you said you just got it done, so what did you do? install a motor?
Old Jan 17, 2007 | 05:34 PM
RoughRex's Avatar
It's Radiation Therapy
Sorry man but your posts are totally unclear as to what "i just got my car done i did a vert" means. We don't understand what you are asking.
Are you saying you just got a car? and it's a stock vert? Or did you just do some work to the car and now there is a problem?
Old Jan 17, 2007 | 05:36 PM
my car floods and i can,t seem to find out why
Old Jan 17, 2007 | 05:39 PM
j-rat i just rebuild my motor and installed it
Old Jan 17, 2007 | 05:43 PM
J-Rat's Avatar
Alcohol Fueled!
Well, the obvious answer would be... The motor is still breaking in and is prone to flooding.
Did you re-use housings, ets?
Old Jan 17, 2007 | 05:48 PM
RoughRex's Avatar
Ahhhh... could be a few things
I suggest double checking to make sure you injectors are wired correctly (primary wires to primary injectors) also make sure you have the primaries and secondaries mixed up.
Also read this thread:
https://www.rx7club.com/showthread.p...20&page=1&pp=15
Old Jan 17, 2007 | 05:53 PM
gingles's Avatar
your link dont work rex
Old Jan 17, 2007 | 10:14 PM
RoughRex's Avatar
ah... my mistake, I copied an abbreviated link.
Here is the correct link:
https://www.rx7club.com/showthread.p...0&page=1&pp=15
Old Jan 18, 2007 | 12:44 AM
trainwreck517's Avatar
Rx-hippie
Like J-rat said, sounds like it still has low compression since the motor isn't broken yet. Drive the car around and try to put as many miles on it.. Remember not to rev over 3-4krpms before you hit 2,500miles... after that point slowly increase rpms..
Search for "Break in procedures" for more info.
After 2k miles, check compression.. engine should have over 100psi on all faces on both rotors.. and you shouldn't have a flooding issue after that.
Also try to make sure the car is fully warmed up before shutting it down, then can help prevent flooding on the next startup.
Old Jan 18, 2007 | 09:38 PM
thanks guys i'll check the injectors i think thats the problem
Kyo
Apr 13, 2019 09:24 AM
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
zuesskroph
Aug 13, 2015 06:05 PM
