Can i take out the water outlet?
Old Jan 17, 2007 | 01:59 PM
bart_heemskerk's Avatar
Bart
How is the water outlet fitted? is it threaded? Is it pressed in?
Old Jan 17, 2007 | 02:13 PM
Rx-7Doctor's Avatar
It's pressed in and why do you want to remove it?
Old Jan 17, 2007 | 02:24 PM
Bart
I want to take it out and fit a temperature sensor in the tube. By the looks of it it seemed a threaded fit.
Thanks for the quick reply.
Old Jan 17, 2007 | 02:27 PM
Rx-7Doctor's Avatar
You could always just drill and tap near the end and cap off the ends with rubber caps.
Old Jan 17, 2007 | 02:34 PM
Bart
I want to maintain the two outlets.
The thing is that the engine is placed in a different car and i want to connect the temp sensor which belongs to the car. But the sensor is much to big to fit in the hole. So i want to make it in the tube.
Old Jan 17, 2007 | 02:43 PM
Jeff20B's Avatar
Lapping = Fapping
That probably won't work. I chose a rear plate with a threaded fitting specifically due to this issue. Racing Beat sells a block off bolt for this, which was required for my project.
It would be best to consider installing the temp sensor somewhere in or near the waterpump. I installing mine in the upper radiator hose. It only reads when the theormostat opens, but that's ok with me.
Old Jan 17, 2007 | 02:49 PM
trochoid's Avatar
Old Fart Young at Heart
Simple, if you aren't using the automatic choke of FI. Find an adapter and install it in place of the temp sensor in the back of the waterpump housing. If you need that sensor, there is a land next to it that can be tapped.
And before I get called, I know he's not running FI, lol.
Old Jan 18, 2007 | 12:36 AM
Bart
Ok, i'll put it in the waterpump. I don't need the automatic choke sensor, so i put it there. Thanks
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Turblown
Sep 30, 2015 05:58 PM
