Power FC Power Fc Work In European Fd3s ?
Old Jan 17, 2007 | 01:10 PM
jef57's Avatar
Question Power Fc Work In European Fd3s ?
hello,
i think there is different part such fuel system between usa FD AND EUROPEAN FD
so I would to know if APEXI power fc would work with european FD with no problem.
I'm really not a Dyno man and i 'm little afraid to make some mistake with this apexi ecu
there Is some differrence between US Power FC and Japanese Power Fc?
thanks FOR YOUR HELP
Old Jan 17, 2007 | 01:37 PM
jef57's Avatar
Bump......
Old Jan 17, 2007 | 04:52 PM
jef57's Avatar
Bump
Old Jan 17, 2007 | 09:05 PM
fd3s7007's Avatar
whilst i'm not 100% sure but JDM's here do not have EGI.
Old Jan 18, 2007 | 01:44 AM
EFS.O's Avatar
Yes,it will work fine.
Old Jan 18, 2007 | 04:24 AM
jef57's Avatar
So I Need Just To Cut The 4 Wire To Install It Properly!?
Old Jan 18, 2007 | 01:31 PM
Montego's Avatar
Don't worry be happy...
Top Answer: 1
First and foremost.
Power FC needs to be tuned (that's the whole point of a stand alone ECU ). Therefore, Is there a tuner that you can go to in france? If there is you should be asking him.
Base maps on the PFC are leaner than the stock ECU IIRC. So if you plan to just run base maps @ 10 psi you are wasting your money.
Find out what ECU your local tuner is familiar with, and use that particular one. If there are no capable Rx-7 tuners then IMO you should be in the market for a pettit or M2 ECU and run your car at moderate boot levels.
Old Jan 18, 2007 | 02:53 PM
rx7italy's Avatar
hi...i've a european version (i'm italian) and i've a pfc!!! it work very good!!!! but you don't must cut the wire!!!!
Old Jan 18, 2007 | 03:10 PM
Veger's Avatar
On a jap car you dont need to cut the 4 wires, just plug it in and follow the rest of Dale Clarks FAQ
http://www.clubrx.org/media/pfc/PowerFC_FAQ.pdf
BUT DONT CUT THE WIRES ON A JAP CAR
Old Jan 18, 2007 | 05:23 PM
jef57's Avatar
I don't have a jap car, my Rx7 is a European
SO cut or not cut ?
in fact why us fd need to cut Wire?
Old Jan 18, 2007 | 05:37 PM
Montego's Avatar
Top Answer: 1
^^ that's why I was saying ask a tuner who knows. lol
Old Jan 18, 2007 | 06:01 PM
jef57's Avatar
prob is no one here in french know how to tune a fd..................
but according to faq power fq and other euro fd with apexi pfc i should cut............
Old Jan 29, 2007 | 06:07 AM
Speedworks's Avatar
I had a PFC on my euro FD for over a year. I cut the 4 wires and never had any problems
Old Feb 16, 2007 | 01:23 PM
rx7fddriver's Avatar
Newbie
I have the same problem/question as jef57
I have ordered a PFC.
The vendor says it is pregprogrammed with a several base map for Japanese domestic market vehicles and minor initial tuning/mapping is recommended for best results. (whatever it is - minor)
I heard there are differences in the octane level.
My car is a european 1992 FD – without any tuning!!
I want to use the PFC only for monitoring (Watertemp + Boost etc).
Can I use the new Apexi Power FC without any map-tuning?
Or if necessary, can I make modification diy?
I don’t want go to a professional although he is worth the money
but i would like avoid to drive 500 km.
Thanks
Thomas
Old Feb 18, 2007 | 03:30 AM
rx7twin's Avatar
i have a german fd that i imported to norway and orderd a pfc from www.rx7.com with a map for my mods and it works like a charm afr is good all the way upp the rmp range
and YES i did cut the 4 wires and my ac works on all 4 speeds
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
andyvideopro
Aug 11, 2015 09:16 PM
