Door, And Hatch Locks...
Old Mar 13, 2002 | 04:21 AM
RotorMotorDriver's Avatar
Seven Is Coming
Where can I get a matched set of these? My key for my ignition on my 83 GSL works really nice, and is showing almost NO signs of wear (unlike the 85 GSL which is almost compleatly smooth), but when we bought the car, it only had one key which fits the ignition, and one door, im sure it fits the other one too, it just doesnt work right, and it doesnt even try to operate the back hatch. So im thinking I'll just buy three locks, one for each door and one for the hatch and have two seperate keys. One for the ignition, and one for the doors and hatch. Ive tinkered with the locks on this car to get them to work the same way I got the ones on the 85 GSL to work, but no luck, so im thinking its just time to replace them.
~T.J.
Old Mar 13, 2002 | 04:23 AM
yayarx7's Avatar
Are you Nucking Futs?
I saw those somewhere?
You know you can get the key code off the passenger door lock mechinism and the dealer will cut you a brand new key. you might try that first, as your tumblers could be OK. They are probably as worn as your key though.
Old Mar 13, 2002 | 04:30 AM
yayarx7's Avatar
mazdatrix has 84-85 sets($324 OUCH), VB has ignition locks.
Old Mar 13, 2002 | 09:42 AM
hanman's Avatar
go to a local locksmith. He can make one key fit all locks. They quoted $40 for mine.
hanman
Old Mar 13, 2002 | 09:54 AM
rotorhead's Avatar
in the rice section of my local 'advance autoparts', i saw a set of matched, universal barrel locks(where the key is a short notched tubey thing) for around $40 i do believe. not sure what to do about the ignition though
Old Mar 13, 2002 | 10:59 AM
Directfreak's Avatar
I am a Jeeper Now.
Use this opportunity.
Get Remote-Keyless Entry. There are plenty of kits out there.
Probably set you back less than 100 bucks, you can tie it into an Alarm system, and be REAL Happy.
I had it on my previous SE, WITH a small switch between the power window buttons. Looked great, worked with the alarm, and I never screwed up any more locks.
Old Mar 13, 2002 | 11:58 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Just seen a set on ebay, it was a couple days ago, but at for what it goes for, ill just use my alarm and the key that fits the ignition lock
Old Mar 13, 2002 | 02:10 PM
riffraff's Avatar
smog nazi destroyer
only problem is for those of us who donot have power locks.. a remote keyless entry system would be a lot more work since none of the wiring is there
Old Mar 13, 2002 | 03:02 PM
I am a Jeeper Now.
Its a Universal Kit. None of the First Gen RX-7's come with Door Locks. You have to add them on, as there IS NO Wiring there for anyone.
Autoloc Stand Alone Keyless Entry / Power Door Locks for $125
It's Real Cheap, and can be installed in an afternoon taking your sweet time. I am sure the guys who do this for a living can point you to even cheaper solutions.
IF you have an Alarm that controls Power Door Locks, it that much sweeter. Trust me, you'll want to do this regardless of whether you fix the locks or not.
Old Mar 13, 2002 | 03:27 PM
rotorhead's Avatar
Originally posted by brake
it doesn't cost as much as some of the other options and is better then a ghetto 3-key autozone jobber.
i didn't get a really good look at the locks as to quality. the LED washer nozzles and honda civic push start buttons kinda made me want to leave....quickly.
Old Mar 15, 2002 | 12:24 AM
smnc's Avatar
EliteHardcoreCannuckSquad
I won that aution...
I wanna get power locks too...
Old Mar 15, 2002 | 07:11 PM
85RX7GS's Avatar
Victoria British has all the locks and they are reasonably priced.
