Know anybody to roll their fenders?
Old Mar 12, 2002 | 11:56 PM
Crazy_Jake's Avatar
What is the process of rolling fenders, and does it make your fenders kinda stick out like a semi-wide-body? Or does it roll the inside of the fender? How much extra tire can fit with rolled fenders?
Old Mar 13, 2002 | 12:29 AM
Crazy_Jake's Avatar
Originally posted by gmonsen
never done it, but there's a tool you rent from a tool rental place or body shop that does it. you have to be careful to roll it slowly, several times, so that you don't crack the paint or you'll have to reshoot. personally, i'd plan on repainting when you were done. sand off the paint around the lip and repaint there, though ive seen it done so well you don;t have to. -gordon
so it actually pushes the fender out some to allow for a bigger tire? does it look good or like crap?
Old Mar 13, 2002 | 12:46 AM
martini's Avatar
No, it doesn't push the fender out.
You know how your fender has that edge that sticks in to the wheel well? The part that the plastic mud covers attach to? Well, sometimes when going with oversized tires, under hard cornering, or launching, the tires will actually touch that part of your fender, and it's a fairly sharp piece, so it will cut into your tires...Thats not good.
So, you roll that piece, meaning, you fold it up and against the inside of the fender.
Here's a little how to on an Integra, it'll give you the general idea. If you do it slowly and carefully, you shouldn't have to repaint .
http://integra.vtec.net/wheels/rollfender.html
Old Mar 13, 2002 | 12:53 AM
HedgeHog's Avatar
Rotary Poseur
Haweka makes the tool for rolling fenders. It clamps onto your hub/brake rotor and follows the arc described by the arm. At the end of the arm, a roller clamps to your fender edge and works it in.
IIRC, TireRack rents it out free of charge to their customers (w/ deposit). However, i also recalled a back log of ppl wanting it.
Old Mar 13, 2002 | 12:54 AM
Crazy_Jake's Avatar
Ok, cool. Always wondered exactly what that meant. What about putting on fender trim like the RE Amemiya trim will this allow for a wider tire? I'm thinking no, because if the tire sticks out that far then if you hit a bump you'll just run the tire into the fender. So is it just for looks?
Old Mar 13, 2002 | 01:19 AM
JoeD's Avatar
ya...if you mold in the flare and cut off the portion of the existing fender underneath.
Old Mar 13, 2002 | 01:22 AM
dclin's Avatar
Perpetual Project
Umm, yes - back log would be an appropriate statement, as that I finally got my turn 6 months after ordering!
If you have a 93 with the primer problem (and you are not willing to repaint)- or even a 95 - I don't suggest it. Combining the paint adhesion problem of the 'organic' primer Mazda had taken a fancy too, coupled with the fact that the newest (US) 3rd gen will have 7 year old paint by now means high likelyhood that the paint will crack. (your suppose to use a heat gun to soften it up a bit though).
On top of that, the front fender lip/edge does not follow (not by a long shot) a perfect radius as the tire lip tool wants to follow (it being attached to the hub and all), so a bit of finessing was in order.
Actually, they only real part you need to roll is the 9 to 12 (1ish) o'colck positions, as that this is the problem area for 3rd gens. At this part of the fender lip, the fender line closes radius much quicker. This is where tall diameter tires love to catch the fender lip when you are turning the steering wheel and entering a drive way going too fast (compressing the suspension).
I have a picture of the lip pulled out on someone's car, but Photopoint is holding it ransom for another $24.95 + shipping and COD fees for a burnt CD-R.....
Old Mar 13, 2002 | 02:24 AM
black99's Avatar
Lurking..................
Yeah that is correct.. Aren't you supposed to do that with the RE and all other fender flares? So that you truly reek the benifits of it?
Thus he wouldn't need to roll the rear fenders with flares if the flares were installed correctly? Is this correct?
Old Mar 13, 2002 | 10:54 AM
Crazy_Jake's Avatar
how much more clearance does the RE fender trim give?
Old Mar 13, 2002 | 11:54 AM
dclin's Avatar
Perpetual Project
If you are talking about the RE Super G (?) body work, the Legsport FD runs 18X10 +44 front and 18X10 +18 rear, with a nice tucked in look. That means the total fender width added is about 1 1/2 inches or so. Sorry - small pic, I'll have to take a pic out of my RX7 Magazine for a close up (#10 for those that have it I think).
Old Mar 13, 2002 | 08:46 PM
JoeD's Avatar
nah, he is talking about these fendes:
wheel offset asside, im assuming you can run up to a 40mm wider tire with these flares.
