Rotary Drag Racing The place to post your racing stories and info
Strong rear
Old Jan 15, 2007 | 11:20 AM
KBSRX7's Avatar
Strong rear
What does everyone do to keep there rear housing from breaking? I haven't yet, but worried cause 2 guys I know broke theirs. How the hell does cars like RX7.com's and other 9 sec FDs keep from breaking? If I were to replace it what is the ideal upgrade?
I'm currently running upgraded gears, KAAZ diff, Upgraded bushings, and upgraded axles. Is there any casing or bracket out there?
Old Jan 18, 2007 | 06:43 PM
moremazda's Avatar
Gone Race'n
I thought it was the LSD and PPF were the weak links???
Old Jan 19, 2007 | 09:14 AM
KBSRX7's Avatar
yeh stock
Once you upgrade the axles and LSD, it makes it so strong that it makes the rear casing very weak.
Old Jan 19, 2007 | 11:02 AM
joe-c's Avatar
YOUR MOM IS MY ADDICTION
Veteran: Navy
get a ford rear end thats wat im saving up for
Old Jan 20, 2007 | 05:08 PM
BLitzed33's Avatar
There is a rear craddle that Ari, Dan, Peter farrell, Ray wilson, Adam, have made that keeps the diff from breaking in half. Each is a little different in design, but do pretty much the same thing, which is to distribute all the shock and power the full length of the diff case and not just where the PPF hooks to the nose of the case and essentually lifts the whole rear instead of it lifting just the nose and breaking the case in half...this is when the pinion is pushing back and up when launching or wheel hop, I know, I have broken mine half as well,,,but no more now.
Old Jan 21, 2007 | 06:08 PM
showoff's Avatar
anyway this can be made availble to the public??
-dj
Old Jan 21, 2007 | 06:18 PM
BLitzed33's Avatar
-dj
Quite possibly, I will have to check on that one.
Old Jan 21, 2007 | 06:29 PM
showoff's Avatar
pm me and lemmme know if its a 1off thing iam interested
-dj
Old Jan 23, 2007 | 07:42 AM
KBSRX7's Avatar
Pics
Can anyone provide pics of this? If I can't buy it I'll have to fab it!
Old Jan 23, 2007 | 10:43 PM
BLitzed33's Avatar
Ray says pfsupercars will be making them for the public soon.
Old Jan 24, 2007 | 03:44 AM
showoff's Avatar
sounds good... thanx
Old Jan 24, 2007 | 01:57 PM
gnx7's Avatar
Blitzed- It sounds like you are running one of these custom diff braces. Can you post pics please? I have an idea what it is going to look like; however a pic would be great.
I'm going to be sending 750rwtq+ thru my FD diff on DOT slicks. Setup is 3:90 gears, Mazda Comp clutches in an S4 T2 LSD, 300M axles and I want to know about your brace as well as others.
I have 2 complete back up spare diffs with 3:90's and S4 T2 LSD installed already expecting some breakage as the 8" ring gear can only handle so much. I don't think the 300M axles will break.... simply the case or the gears themselves.
Old Jan 24, 2007 | 02:15 PM
slo's Avatar
slo
registered user
If the case holds up. the axle stubs will break.
Old Jan 24, 2007 | 03:42 PM
BLitzed33's Avatar
Doubt the axle stubs will break with the 300M chromoly, the next weak link would be the CV cups themselves.
BLitzed33's Avatar
I will see about getting some pics up here
Old Jan 24, 2007 | 05:03 PM
gnx7's Avatar
Forgot that the stub axles could shear also. Lovely.
Well after 2 strikes if I blow up these setups.... I'm going Viper Dana 44 pumpkin with custom 300M axles.
Old Jan 25, 2007 | 05:02 PM
ErnieT's Avatar
Living life 9 seconds at a time
The knuckles attaching the axle to the diff will crack. Had this happen too. Not really much you can do about. Good thing is its a cheap part.
Th0m4s
Feb 26, 2019 02:04 AM
