1987 SE rx7 4x114.3
1987 SE rx7 4x114.3
Hey guys i need help on ordering rims... i fould a pair and checked the stock size on the bolt pattern and etc... but the offset?
It said the offset for stock is 20+mm? so would i be able to order rims 20+ and above or they have to be the 20+MM offset?
I was looking at getting some motegis that are +35 MM offset?
let me know either by posting reply or PM i will check when i get off work thanks.
i ran 15x7 +0 offset rewinds on my base FC. the rears were perfect and the fronts stuck out a half inch at stock height. This is also the fault of the tires, azenis have huuuge blocky sidewalls. if i had lowered it the fronts would have cambered in and fit perfect.
Best Offset
I am just looking for the best off set i need to go with on my FC i will be lowering and stuff later on... so i dont want it to rub on the fenders and what not... any ideas? or a range i should look for on the offest?
Offset for 1986-1987 rx7
anyone got the best off set... or a range that should be decent... i will just be mad if i ordered rims and they dont fit right... i will be lowering my car at a lower time... and stuff...
