brake rotors
Old Jan 14, 2007 | 08:01 PM
RX7 allnight's Avatar
brake rotors
trying to change the brake rotors.. 1988 Vert
i have the brake caliper off along with the rotor question is how do you change over the bearing? i bought the brake rotors from ebay theres two philip screws on the brake rotor itself but they wont budge any help thanks?doing the front right now..
Old Jan 14, 2007 | 08:18 PM
Icemark's Avatar
You have to remove the screw, then the whole brake rotor comes off
Old Jan 14, 2007 | 08:42 PM
the brake rotor is already off, iam trying to switch the bearing.. from one brake rotor to another theres two screws on the brake rotor do i remove these to remove the center to switch it to the other brake rotor?
Old Jan 14, 2007 | 08:47 PM
Icemark's Avatar
The bearings are on the hub, not on the brake rotor. The hub with the bearing stays on the car. It does not get removed to replace the rotor.
Old Jan 14, 2007 | 08:52 PM
iam kinda lost mark, i removed the brake rotor and the bearing came with it.. it seems to me the inner part of the old brake rotor needs to be placed into the new ones...? thanks for your help
Old Jan 14, 2007 | 08:56 PM
Icemark's Avatar
You take off the caliper, you remove the two screws, you remove the brake rotor from the hub.
Did you just take out the big nut in the middle or something??? If so, you took off the hub.
Normally the hub stays on the spindle (and car) when replacing the brake rotor.
Old Jan 14, 2007 | 08:58 PM
so i dont even have to remove the 17mm nut that holds the hub/bearing? to remove the brake rotor just these two screws?
Old Jan 14, 2007 | 09:00 PM
riverzendz's Avatar
Interruptor Illuminada
It sounds like that's what he did. He mentioned, above, that the screws holding the rotor on would not budge.
Old Jan 14, 2007 | 09:03 PM
ok things are clear now.. darn those screws are tough!! they wont budge iall go try some more.. yeah i removed the 17mm nut to get to the hub.. well now i know how to change my bearings.. so i need to get these screws off thanks for your help mark
riverzendz's Avatar
That is correct.
Old Jan 14, 2007 | 09:09 PM
drft_180sx's Avatar
just drill the heads of the screws off....and when putting new rotor on the hub put some anti-seize on it, that'll help prevent the hub and rotor from fusing together...
btw the screws are there just for holding the rotor on for ease of installing the wheel. the screw doesn't actually have anyother purpose.
Old Jan 14, 2007 | 09:12 PM
k thanaks any tq. specs for the hub? or any other brake parts i should know about? like brake caliper?
Old Jan 14, 2007 | 09:50 PM
drft_180sx's Avatar
just hand tighten the brake caliper on...50lbs.ft? also after drilling the screws out if the rotors won't budge, then you can use a bolt (i found that the rear bolt that holds the caliper in position fit . NOT the ones that hold the bracket down.) and screw the bolt down to release the rotor without damaging anything.
Devon300zx
15
Sep 16, 2015 06:57 AM
Frisky Arab
Sep 4, 2015 06:17 PM
