Twin Scroll question
Old Jan 14, 2007 | 06:08 PM
NaturalSmooth's Avatar
T04Z 13B-RE
So I just finished porting the WG on a spare turbo that I have (that I will be putting in) and after I removed the intake, I realized that something wasn't quit right on my twin scroll actuator. I have a spare manifold, should I just remove the whole twin scroll sytem?
Old Jan 14, 2007 | 06:10 PM
K-Tune's Avatar
FD Daily
i dont miss mine.
Old Jan 14, 2007 | 06:12 PM
stevensimon's Avatar
either pull it out and weld it up or get an ebay tubular mani. or even just coat hanger wire that one open. or you can swap em over but meh
Old Jan 15, 2007 | 04:04 AM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by FBDrifter
i dont miss mine.
Probably because yours wasn't working when you remove it. The difference when removing a working system is noticable.
stevensimon, a replacement actuator would be cheap. Buy one off someone who removed theirs and doesn't miss it...
Old Jan 15, 2007 | 08:34 AM
T04Z 13B-RE
Do you think I should notice a big performance improvement from hooking it back up or removing it?
Old Jan 15, 2007 | 10:07 AM
Aaron Cake's Avatar
Engine, Not Motor
Fix it. Just replace the banjo bolt that is missing.
Without it, on a basically stock car, you will notice a significant decrease in turbo response down low.
Old Jan 15, 2007 | 11:10 AM
HAILERS's Avatar
HAILERS
Juuuuuust in case you fell for some of the bullshit in one or two posts above..............If there is no vacuum going to the actuator (unlikely in your case with the banjo bolt missing) then the twin scroll actuator is to the FULL OPEN position, much like it would be when and if the system was fully operational and the rpm were over 2800 rpm. IN other words you would do nothing to the actuator to make it open if it was not getting vacuum.
Buy a banjo bolt and or make one out of a common bolt and install it.
http://www.pegasusautoracing.com/gro...upID=BANJOBOLT
http://store.summitracing.com/egnsea...s=false&N=+115
http://www.jegs.com/webapp/wcs/store...58024_-1_10019
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
