Microtech I need some electrical help.
Old Jan 12, 2007 | 02:48 PM
turbo80cid's Avatar
I need the best way to wire in a toggle switch to control a momentary on push button switch that will activate the “2 step” rev limiter on my Microtech LT-8.
The toggle will be on the dash and the momentary on push button will be on the clutch pedal.
The Microtech has an aux input that need to see +12v to activate.
Could someone draw me a diagram?
Thanks,
Bill
Old Jan 12, 2007 | 04:36 PM
hondahater's Avatar
spending too much money..
yeah I want to set this up on mine as well. I'm sure they have something floating around. Maybe not.
Old Jan 14, 2007 | 01:13 PM
turbo80cid's Avatar
well I did it today but it doesn't work that well.
I ran power to a toggle switch
then from the toggle to the momentary on push button
and then from the momentary on push button to the Microtech.
I set the rpm limit @ 3500
enrich to 5.00
timing to -30
didn't build any boost.
I'll mess with it some more later today.
Old Jan 15, 2007 | 11:58 AM
turbo80cid's Avatar
Ok, I messed with it some more last night.
I guess I was just scared to stand on the gas.
With the same settings as above it works...it just takes a few seconds to really start working.
No popping or banging just a slow up and down rev….. a few hundred rpm's and it made 5psi on a stock S5 turbo & stock ports.
Old Jan 19, 2007 | 04:33 AM
hondahater's Avatar
hum interesting. Not sure if you would have a few seconds to spool up a turbo on the strip. Most of the time when I see this it only takes a split second.
Old Jan 19, 2007 | 06:43 AM
turbo80cid's Avatar
Well I'm pretty sure my turbo is due for a rebuild....making some noise. And maybe a few seconds would be exaggerated. Also the weather here has been terrible so I haven’t had a chance to get out and really use it. I’ve only rev’ed it in the driveway…..and I don’t really like doing that because I like my neighbors.
Old Jan 27, 2007 | 09:21 PM
red87tll's Avatar
needs a cheaper hobby
i've got the set up right here... i'll make a pic of the set-up i am running for the switch...does any one know if the clutch switch outputs a 12v+ siganl?
Old Jan 27, 2007 | 10:20 PM
red87tll's Avatar
here ya go... this is the setup that i am running, should work for all if i drew it correctly
http://i71.photobucket.com/albums/i1...g?t=1169960867
with this wiring---you must push in the clutch (if the clutch provides a 12v+ signal when pressed) then push the arm button. it will pull the relay closed and keep power to the ECU as long as the clutch is pressed, keeping it in "2 step" mode. once you have released the clutch the ECU will return to "NORMAL" mode, you must re-arm it in order to become locked back into "2 step" mode.
Old Jan 27, 2007 | 10:24 PM
red87tll's Avatar
enrich to 5.00
timing to -30
I dont think you should set a revlim.. that cuts the fuel from the motor...
instead, just set it up to crank the fuel up about 50% and pull the timing back about 30* once it hits 3500rpm..
Old Jan 27, 2007 | 10:45 PM
turbo80cid's Avatar
you have to give it a limit....so the ecu knows where to hold the rev's.
i don't understand what you are trying to say.
also it's the aux rev limit
Old Jan 27, 2007 | 11:26 PM
red87tll's Avatar
oohhh, i though u were just trying to set the normal revlim to 3500 ...
heres a link to some other setup stuff if it helps.
http://www.microtechefi.com/forum/vi...ntrol&start=15
sorry about the confusion, i miss understood.
-j
Old Jan 27, 2007 | 11:32 PM
turbo80cid's Avatar
ok, thats cool.
and thanks for the link.....I've read it before.
I've got it working but on the street it's hard (very hard) to get traction.....still fun.
Old Jan 30, 2007 | 11:47 PM
hondahater's Avatar
cool, thanks for the easy to read diagram. Will be setting this up for those times at the track.
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
