83 rear end swap
Old Mar 12, 2002 | 04:52 PM
82transam's Avatar
Never Follow
83 rear end swap
I have a 83 S with an open differential and drum brakes. I want to put a GSL rear end (LSD, disk preferably out of the same year) in my car. What is involved in doing this? Will I have to change the master cylinder? anything else? Will it just bolt right in? Thanks
Old Mar 12, 2002 | 06:23 PM
riffraff's Avatar
smog nazi destroyer
i am looking into doing the same swap in my 79.
i think it is just a matter of droping your current rear axel and putting the new one in. the break lines will have to be changes , and also the emercency break line.
hopefully someone esle can give more detailed information, as i need it too
Old Mar 12, 2002 | 06:45 PM
82transam's Avatar
Never Follow
Yea the main thing I'm concerned with is whether the master cylinder is the same for disk and drum brakes. I'd assume it isn't becuase disk and drum have very different requirements to power them. I know there are probably a ton of you guys out there that have already done this. Any pictures, and/or detialed info would be greatly appreciated. Thanks
Old Mar 12, 2002 | 11:57 PM
riffraff's Avatar
smog nazi destroyer
rb and rp both have ss braided break lines for 79/80 with rear disks, so i would imagine that that then incorporates the different threads...
who knows. i will figure it out soon enough. i will probably find a used 81/82 gsl rear end in may and do it then (get my new suspension at the same time too)
Old Mar 13, 2002 | 12:00 AM
riffraff's Avatar
smog nazi destroyer
i donot think that i have seen a seven crumple like that. what did you hit?
Old Mar 13, 2002 | 12:27 AM
mperformance's Avatar
brake sorry that happened to you man...ouch!
Old Mar 13, 2002 | 03:30 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Holy **** dude that sucks , that was the master cylinder...
Old Mar 13, 2002 | 10:30 AM
rotorhead's Avatar
actually, i did the swap with my 82 about 3 years ago. i've had 3 years of trouble free braking too. and i'm VERY rough on the brakes. it was a fairly easy swap, especially considering i'm not much of a mechanic. bolt comes off... bolt goes on. very straightforward swap. not sure what could've caused the problem that 'brake' had, but damn! that really sux! hope nobody got seriously injured in that shiznit!
Old Mar 13, 2002 | 10:33 AM
rotorhead's Avatar
btw, it was an 84-85 disc lsd rear end i put into my 82. the only weirdness was matching up the driveshaft with the diff flange... had to swap out the flange and seal on the diff.
Old Mar 13, 2002 | 11:53 AM
MarkPerez's Avatar
Tennis, anyone
One of the first things i did to my car, was the rearend
swap,i'm 82 GS, i went to the junkyard and from different year cars i put together a rearend with disk's
and LSD,i don't know the years, but i used my same
drive shaft,,,what i did was go through all the rearends
at the boneyard and put together MY rearend on the
side out of the best parts i could find. it took a while
to do that but hey,,why not,,it was a direct bolt in project that took 1 person about 2 hours,,i did not
change the master cycl. and have had no problems at all
make sure to use LSD oil when you install the new rearend,,the gearing and LSD are better then what was
in the GS,,,oh and the disks too
Old Mar 13, 2002 | 02:06 PM
82transam's Avatar
Never Follow
yea man sorry to see yer car like that. So you're saying that an 84/85 rearend has the same flange as 83 right? So it should thoretically just bolt in. And after seeing that pic I'll be sure to change the master cylinder as well. While I'm at it I might as well go with ss brake lines too. Thanks for the info
Old Mar 13, 2002 | 02:20 PM
riffraff's Avatar
smog nazi destroyer
how did you guys lift the car to do the swap??
Old Mar 13, 2002 | 02:37 PM
MIKE-P-28's Avatar
pick it up with the rear end, then place jacks stands on the outside of the car where the frame is tough, thats what I do
Old Mar 13, 2002 | 02:38 PM
riffraff's Avatar
smog nazi destroyer
and next question. can an amature like me do this, or would i be better off taking it to the local seven racing shop and paying them 50 bucks an hour to do the swap?
Old Mar 13, 2002 | 04:46 PM
MarkPerez's Avatar
Tennis, anyone
of any disk brake system,isn't 70 % allways front rotors.
70% of stoping power is front, 30% rear.
oh,,and your right,,the e-brake cable had to be changed
for rear disk's
Old Mar 13, 2002 | 08:31 PM
82transam's Avatar
Never Follow
Thanks for all the good info, now it's off to the junk yard to find a good 84/85 rear.
Old Mar 14, 2002 | 02:52 AM
RotaryMiata's Avatar
Exclamation
Originally posted by mark perez
of any disk brake system,isn't 70 % allways front rotors. 70% of stoping power is front, 30% rear.
Not always! It greatly depends on the weight balance of the car and the suspension setup.
The more weight towards the back of the car, the more the rear brakes take care of things (unless your suspension sucks and the car takes a nosedive when you stab the brake pedal). Example: BMW tests show that their new M3's weight balance is 49/51 still, and 43/57 under braking.
Not trying to be nit-picky, just accurate.
Old Mar 14, 2002 | 03:25 AM
V8kilr's Avatar
my fronts are not currently working at all right now,
and ill say you would be amazed how much those back brakes actuall work,
not to mention my car is gutted in the back.
i do wics i had my front though,
i pray everyday someone in front of doesnt lock em up.
id be screwed
if i hit the brakes to hard the rears just lock and i slide,
there worthless in the rain,
oh and i also have drums
84 gs welded diff
Old Mar 14, 2002 | 05:13 AM
yayarx7's Avatar
Are you Nucking Futs?
that does not sound safe at all. please stay out of Texas till you get that fixed, or better yet, come to Texas and I'll fix it for you.
Old Mar 14, 2002 | 07:34 PM
82transam's Avatar
Never Follow
hey riffraff **** paying someone to do it. I do all my own **** and not only is it satisfying to know that your riding on something you put together but youy also learn a lot in the process. I'm definatly gonna swap my rear this summer when school is out. Peace
Old Mar 14, 2002 | 09:19 PM
riffraff's Avatar
smog nazi destroyer
i definatly know about satisfaction with the car. i more or less put mine together.. i just didnot know if the rear end would be more involved than i could do with limited knowhow and limited knowledge... but i will probably give it a shot.. do that and the suspension upgrade at the same time
Old Mar 14, 2002 | 10:25 PM
iyaseven's Avatar
riff, iam sure i read that mazdatrix sells adapters the 79'-80' brake line thread difference.
