dual digital EGTs
Old Jan 10, 2007 | 08:02 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
dual digital EGTs
as i tune my way toward a gazillian hp i have learned a few things. perhaps number one is that if you properly instrument your car you don't have to be very smart to get it right.
instrumentation may be one of the better investments. it generally is quite a bit cheaper than blowing motors and wondering what happend and, OBTW, laying out serious money to fix the beast.
thru my power fc/datalogit i monitor and log digitally both rotor's egts pre turbo(s), exhaust backpressure preturbo of course, fuel pressure and all the other stuff like knock and afrs etc.
thanks to jeff feltman's electronic diagram i built my own (o k he wired it for me)translator box between my thermocouples and the datalogit. the box takes the sensor's voltage and changes it into 0-5 volts for my datalogit to translate into temperature. a relatively simple deal and inexpensive if you have the inclination.
OR
you can go to FJOracing.com and nose around til you find their dual egt translator box. retail about 160. not a bad deal. you will then need to buy a couple of fast reacting sensors/thermocouples. i recommend and use teamrip.com. instantaneous. 45 each.
BTW, i do think that AEM has such a box. maybe 4 channel.
so there's another option for you.
howard coleman
Old Jan 10, 2007 | 08:19 PM
Howard, are you running the GZ LIM? I seem to recall reading that due to the equal length runners it helps to equalize EGTs between front and rear rotors.
Old Jan 10, 2007 | 08:47 PM
i am running an UIM and LIM ported by Jose Le Duc. my egt's are within 30 degrees of even under boost.
i did finally do an experiment this summer where i placed one of the probes pre turbo and one post turbo to find out what the actual diff was on my setup. i found it varied greatly with manifold pressure but was about 340 degrees at one bar and above. generally i had always heard 200 degrees.
i do run a 3 inch DP from each turbo... my exhaust back pressure is 18 psi at 15 psi boost.
howard
Old Jan 10, 2007 | 09:12 PM
books's Avatar
How far down was your post turbo probe and what was its temp? Was this without alky?
Old Jan 11, 2007 | 06:41 AM
3 inches from the V band. no alky. sorry, i don't have the logs as to temp.
hc
Old Jan 11, 2007 | 09:38 AM
dubulup's Avatar
development
I love it when howard coleman takes us to school. Good stuff howard, you are always improving the way I plan to use my components!
I'm running out of inputs my Haltech will log...worse case, if I could only log one EGT (pre-turbo) which would I choose? (I have seen on occassion my front runner glowing more than the rear)
unequal LIM, unequal Exh. mani...but I can trim each inj as I see fit.
My thoughts are...
If I keep an eye on the dual EGT gauge, and trim the secondaries as necessary. I should be able to obtain accurate "tune-able" data using one pre-turbo EGT...if of course, I can't find another input.
Old Jan 11, 2007 | 12:56 PM
dubulup's Avatar
development
Found this reading old threads
http://www.simplecircuitboards.com/Thermocouples.html
Originally Posted by At the bottom of the link
This board was designed for car enthusiasts who wish to monitor the temperature of their exhaust gas in order to fine tune their engine’s performance. The design is based on the Analog Devices AD595 (type K) Thermocouple Amplifier and has additional circuitry to enable its use in automotive applications.
Maximum output is 5V DC at 1000 degrees C (1800 F). This board is intended to be used with a DAC device to handle temperature conversion. Requires 12 to 24VDC power. Thermocouple is not included.
$41 shipped.
much cheaper than any fancy name brand...
Originally Posted by jeff48
BTW, I have used this setup with rotary and non-rotary applications. Because the AD595 IC is "instrument quality", this "Ghetto Mod" is EXTREMELY accurate and may outperform most commerical units for datalogging applications.
SCORE!!!
Old Jan 11, 2007 | 03:31 PM
AHarada's Avatar
Can someone explain to me the benefits of monitoring your EGT's. I assume it is a good measure of how hot your turbos are so you prevent overheating them. What about tuning? How can you use this info for tuning your car?
Old Jan 11, 2007 | 03:38 PM
dubulup's Avatar
development
we are talking about EGT's before the turbo...this is useful in tuning timing advance.
here is a snip I grabbed from a post about tuning with EGT's
A. If the AFRs are lean and the EGTs are high you probably want to add fuel to the maps at those points and re-log
B. If AFRs are rich and EGTs are high, you may be experiencing excess fuel being burned off in the manifold, try taking a little fuel out in those cells and re-log.
C. If EGTs are high and the AFRs are in the normal range, you may have a timing problem in that area and you may want to retard the ignition timing in the affected cells and relog.
D. If the AFRs are rich and the EGTs are low, you can take some fuel out in those cells and re-log.
for people using Aux inj, either Meth or H2O, this cools EGT's...which could lead to running more timing advance.
Old Jan 17, 2007 | 01:34 AM
Turblown's Avatar
Turn up the boost
For once good advice on the internet...
Rotary Performance Parts
Old Jan 17, 2007 | 07:25 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
But aren't most EGT's too slow to detect exact point in the map? I always assume EGT gauges were all assumption and not to useful. If I'm wrong, please correct me.
Old Jan 17, 2007 | 08:22 AM
you are probably right as to "most" egts.....
i was given 2 Greddy egt gauges and compared them against my digital setup. they were off significantly and were slow to respond compared to my digital setup.
i literally advertised the two in the classifieds, commented on how inaccurate they were and sold them for shipping cost alone.
as to the slow reacting question.... i use a Power FC datalogit and can, of course, replay my events. my egts correlate instantaneously w the other data.
there is no perceptable time lag. good old electricity travels at the speed of light. that's a bit faster than an analog needle.
howard coleman
Old Jan 17, 2007 | 10:30 AM
Herblenny's Avatar
howard coleman
Howard, thanks for that info.. But I always thought heat transfer to thermocouplers were the problem and only few very expensive couplers will be accurate enough at such high temps.. I guess I was wrong about this.. And if you say they are accurate, I totally believe you! I'm going to pick up a set and give it a try!
PHIL
Old Jan 17, 2007 | 10:54 AM
SPICcnmGT's Avatar
So how exactly are you mounting the probe before the turbos?? Or do you have a single with some room between the turbo and the engine??
And from your info it seems if it was mounted after the turbo(s) that you can basically add 350 to that?? Not the most accurate way to do it, but I'm assuming that would be about the only way to do it for the twins. Or what about running the base map, or stock ECU, on a stock port and measure temps and tune for around that??
Old Jan 17, 2007 | 11:05 AM
Herblenny's Avatar
This is how Dubulup did.. But looks like a single turbo manifold.
Not sure about Stock twin manifolds though.. I have to go look at mine.
Old Jan 17, 2007 | 11:18 AM
Herblenny's Avatar
Old Jan 17, 2007 | 11:29 AM
Turblown's Avatar
Turn up the boost
Most name brand stuff is, even when its expensive, like racepak.
But then again using a single wideband is also too slow...
Old Jan 17, 2007 | 11:54 AM
Twinmani egt probe setup...
Old Jan 17, 2007 | 12:27 PM
as i have previously posted, the readings are instantaneous. end of story.
FYI, the teamrip thermocouples are only about a half inch long past the threads. not at all like the ones pictured a few posts up. i drilled about an 1/8th inch hole in my manifold about 1/2 inch from the 1/2 inch thick manifold flange at the port. i welded a SS bung on and screwed the thermocouple in. it barely protrudes into the exhaust stream. i was able to place both bungs at what i thought was a similar point w regard to the exhaust flow.
as to how you'd do an OEM setup.... it would be next to impossible to infer any pre turbo egt from post turbo due to the restictive nature of the manifold.
howard coleman
Old Jan 17, 2007 | 12:38 PM
SPICcnmGT's Avatar
Ahhh...ok now I see. I couldn't picture the manifold.
That also makes sense with the twins. This is a very useful thread. I may do this when I get the time to remove the turbos.
Old Jan 17, 2007 | 01:52 PM
ReadyKW's Avatar
How about dual probes in the OEM exhaust manifold, preturbo? I see the photo afgmoto1978 supplied. Anyone with experience with this?
Howard, how do you know if your measured temps are accurate?
Old Jan 17, 2007 | 03:36 PM
"how do you know if your measured temps are accurate?"
here's what the AD595 delivers:
AD595 Monolithic Thermocouple Amplifier with Cold Junction Compensation Pretrimmed for Type K Thermocouples
Product Description
The AD594/AD595 is a complete instrumentation amplifier and thermocouple cold junction compensator on a monolithic chip. It combines an ice point reference with a precalibrated amplifier to produce a high level (10 mV/°C) output directly from a thermocouple signal. Pin-strapping options allow it to be used as a linear amplifier-compensator or as a switched output setpoint controller using either fixed or remote setpoint control. It can be used to amplify its compensation voltage directly, thereby converting it to a stand-alone Celsius transducer with a low impedance voltage output.
The AD594/AD595 includes a thermocouple failure alarm that indicates if one or both thermocouple leads become open. The alarm output has a flexible format which includes TTL drive capability.
The AD594/AD595 can be powered from a single ended supply (including +5 V) and by including a negative supply, temperatures below 0°C can be measured. To minimize self-heating, an unloaded AD594/AD595 will typically operate with a total supply current 160 µA, but is also capable of delivering in excess of ±5 mA to a load.
The AD594 is precalibrated by laser wafer trimming to match the characteristic of type J (iron-constantan) thermocouples and the AD595 is laser trimmed for type K (chromel-alumel) inputs. The temperature transducer voltages and gain control resistors are available at the package pins so that the circuit can be recalibrated for the thermocouple types by the addition of two or three resistors. These terminals also allow more precise calibration for both thermocouple and thermometer applications.
The AD594/AD595 is available in two performance grades. The C and the A versions have calibration accuracies of ±1°C and ±3°C, respectively. Both are designed to be used from 0°C to +50°C, and are available in 14-pin, hermetically sealed, side-brazed ceramic DIPs as well as low cost cerdip packages.
combine two of the AD595C chips w the appropriate 0-5 volt conversion circuity, a couple of higher quality K thermocouples, AD's look up table for calibration and........ move on to other things.
howard coleman
Old Mar 8, 2007 | 04:13 PM
Veger's Avatar
Edit ..... wrong place
Old Mar 8, 2007 | 04:15 PM
Veger's Avatar
Duno how this happend but my Quote ended up in the wrong thread :\
Old Mar 8, 2007 | 04:26 PM
fritts's Avatar
Mad Man
You can get those chips as evaluation units for free from the manufacturer shoot they shipped them to me next day. Its an extremely simple circuit to create and run them. The thermocouples cost and possibility of the tips breaking off and going through the turbo has always scared me.
