Single/Vac line install question
Old Mar 12, 2002 | 08:06 AM
Rotary93's Avatar
Retired RX7 mechanic
Question Single/Vac line install question
Guys Im a little confused on something.
I recently installed my XS T04S kit. Upon doing that I took out the solinoids and Vac lines.
My question is...Under the thermostat housing there is a brass airline that goes up behind the thermostat housing (then I loose it).
It used to go to the inlet elbow on the stock turbos pipe. What is it used for? Do need it?
thanks
Anthony
Old Mar 12, 2002 | 08:14 AM
richjackson7's Avatar
i think what your refering to is a coolant line that used to be for the stock turbos... and if so only if your turbo is watercooled do you need it.
Old Mar 12, 2002 | 08:17 AM
Rotary93's Avatar
No Im talking about a Vac line under the thermostat housing...It used to go to the elbow on the primary turbo....
Old Mar 15, 2002 | 11:27 PM
Sidestick's Avatar
I think it taps into the breather in the oil filler neck
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
