saved by the spare
Old Mar 11, 2002 | 06:35 AM
Dan's Avatar
Dan
Unhappy saved by the spare
I got about 1 mi. away from work this morning. It was real cold out, and I after each stop light I would give it enough throtle to hit boost and the back end would get a little side ways. I thought the old girl was just beening peppy. It didnt help that I have a new cd player and was jammin. After a few miles down the road doing about 45 I let off the gas and she hooked hard to the left, thats when I knew I had a flat tire. I pulled over hoping that it was just low. Well as my luck has it the rim almost wore a hole thru the side wall of the tire.
Its a damn good thing the tire needed replaced and that it did not hurt the rim.. Any way guys I need some new tires I still have the stock 93 size rims. could you recommend the best size and what kind of tire? p.s. I want a all-out- proformance tire.
Old Mar 11, 2002 | 07:02 AM
ttpowerd's Avatar
HARRRRRRRRR
s03s run about $180 for 245s...so $720 for all around. Thats your all out performance right there
Old Mar 11, 2002 | 10:21 AM
Bucrx7's Avatar
I second the s03s at 245s all around. You might have a little fitment problem up front depending on your suspension.
